RaceCapturePro2 QuickStart
Revision as of 19:53, 22 December 2014 by Brentp (talk | contribs) (→Prerequisites)
Prerequisites
Quick Start
  5. Open the RaceCapture application.
  6. Click on 'Dashboard'
  7. Click on the bottom right arrow three times, which will display the digital dash. You should see the Utc and Interval channels changing, which means data is being transmitted over USB.
Setting up Bluetooth
  1. Complete the Quick Start steps above, leaving RaceCapture/Pro connected to your computer
  2. Connect the Bluetooth module to the inner of the two RaceCapture/Pro ports on the same side the USB cable connects to
  3. Open the Race Capture app
  4. Click on the top left 'Menu' button
  5. Click on 'Configuration'
  6. Click on 'Wireless' in the list of options on the left
  7. Click the toggle to the right of 'Bluetooth'
  8. Click the 'Write Config' button on the bottom left (down array pointing to a RaceCapture/Pro)
  9. Install the Race Capture app on your Android device from the Google Play Store
  10. Turn on Bluetooth on your tablet and pair with RaceCapture/Pro, password is 1234
  11. Open the RaceCapture app, tap the screen until the RaceCapture logo show up at the top.
  12. Tap the Bluetooth icon at the top right
  13. Select RaceCapture/Pro
  14. After a few seconds you should see a 'Connected to RaceCapture/Pro' message and data will be transmitting to your tablet.
  15. Swipe to the digital dash screen and you should see values changing, pick up your RaceCapture/Pro and move it around, you should see even more sensors changing!
