RaceCapturePro Downloads
Revision as of 16:08, 14 December 2014 by Rdoherty (talk | contribs)
RaceCapture/Pro MK2
App
Windows
Mac OS X
Mac installer coming soon!
Linux
Packages coming soon!
Driver
App
Firmware
See the CHANGELOG file in the .zip file package to see the list of changes for that release
RaceCapture/Pro MK1
Firmware
RaceCapture App
  • Linux: currently supported (run from source code; installer coming soon)
  • Android: port scheduled
  • iOS: port scheduled
Windows
Linux
Previous Versions
Race Analyzer Downloads
Windows XP/Vista/7/8
Latest
Mac OS X
Linux
Release Notes
Release Notes
Sample Logfiles
Previous Releases
Driver Downloads
Windows 8 Note
Windows XP/Vista/7/8 Drivers V2 For firmware version 1.2 and higher
Firmware Downloads
Latest
Firmware Instructions
Release Notes
Release Notes
Previous Releases
Bootloader Releases
bootloader_0.0.2.bin
bootloader_0.0.1.bin
Firmware update utility
