RaceCapturePro Downloads
Revision as of 20:04, 3 January 2015 by Brentp (talk | contribs) (→Linux)
RaceCapture App
  • Use the RaceCapture App to configure and visualize data from your RaceCapture/Pro device.
  • For MK1 and MK2 versions of RaceCapture/Pro
    • MK1 users: ensure you have updated to the latest V2 firmware.
Windows
RaceCapture App v1.2.2
Previous Versions
Mac OS X
Mac installer coming soon!
Linux
Packages coming soon!
Mobile App
USB Driver
  • OS X: No driver needed
  • Linux: No driver needed
RaceCapture/Pro MK2
Firmware
Previous Versions
How to update MK2 Firmware
Save your configuration
Alternative method
  • You should observe a rapidly flashing red LED on the unit: it is in bootloader mode.
RaceCapture/Pro MK1
Firmware
The 2.7.6 firmware for MK1 is considered 'stable beta' - We feel it's much better quality than the previous 1.2.x firmware and RaceAnalyzer combination, but since it is the first V2 firmware and app release for MK1, we are officially calling it Beta. Please visit the Discussion / support forum for help.
Previous Versions
MK1 Bootloader Releases
Firmware update utility
