CAN Bus Integration
Revision as of 21:43, 8 January 2015 by Jstoezel (talk | contribs) (→Controlling a CAN enabled Device)
Researching CAN Bus protocol
Reverse Engineering
Reading a CAN message
Mapping to a Virtual Channel
AIM Mychron 3 Dash
The following information is a sum up of reverse engineering findings documented here: [1]. Example of LUA implementation of the the different packets documented on the Mychron 3 Hack page are provided below:
TODO
TODO
Packet 404h: Control for fields displayed on bottom left of display
TODO
TODO
TODO
Packet 408h: Timing
TODO
