CAN Bus Integration
Prerequisites
Also, if you need to make a custom mapping because no preset exists for your device:
  • Basic understanding of math
  • Basic understanding of data represented as bits and bytes
Preset configurations
Wiring CAN bus
Integrating a CAN-enabled device to RaceCapture involves connecting the CAN bus connections to RaceCapture.
Each CAN device has two wires that provides data:
  • CAN high (CANH)
  • CAN low (CANL)
When you connect the device to the CAN bus, you would connect the CAN high and CAN low wires of the device to the CAN high and CAN low wires of RaceCapture.
Choosing the CAN bus to connect
RaceCapture has multiple CAN bus networks. There is a convention for choosing which CAN bus when connecting a device:
  • CAN1 - typically used for ECUs (OBDII and after-market)
  • CAN2 and higher - typically used for extended sensor networks, such as AnalogX, TireX, etc.
This approach isolates the extended sensors from the car's ECU, especially important when working with OEM ECU networks.
  • Note - this is not a hard and fast rule, but a convention. Advanced users may choose any configuration that meets their needs.
Plug and Play connector system
  • Applies to
    • RaceCapture/Track MK3
    • RaceCapture/Pro MK4
    • PodiumConnect MK2
See the full plug and play harness specification
  • Connector: M8 4P, A coding
Male connector pictured
Pin Connection Notes
1 CAN low White
3 CAN high Green
4 Ground Black
Dual CAN + power interconnect
  • Connector: M8 6P, A coding
1 CAN1 low
2 CAN2 low
3 CAN2 high
4 Ground
5 CAN1 high
6 Power 9-24v / 1A (~12W)
Molex connector
  • Applies to
    • RaceCapture/Pro MK3
RJ45 connector
  • Applies to
    • RaceCapture/Pro MK2, MK3
    • RaceCapture/Track MK1, MK2
Cabling
+12v Brown
Ground Orange/White
CAN 1 High Orange
CAN 1 Low Green/White
CAN 2 High Blue
CAN 2 Low Blue/White
  • Important note for MK2: The +12v connection on the RJ45 is connected internally to the +12v on the terminal block on RaceCapture/Pro MK2. It's recommended you only power via one source - RJ45 or terminal block - if you have both connected at the same time, you may cause back-feeding of power through RaceCapture/Pro, which may cause damage to the unit. Note: RaceCapture/Pro MK3 has internal protection diodes which avoids this issue.
Researching CAN Bus protocol
CAN Bus documentation
  • Channel: (RPM, Engine Temperature, Throttle Position, etc)
  • CAN Identifier: The CAN Identifier for each channel. This may appear in either 11 or the extended 29 bit format. Typically 11 bits are used.
  • Offset: where the data starts within the 8 byte CAN message. An offset of 0 means the data starts on the first byte.
  • Length: Typically 1 or two bytes
  • Scaling: The raw value from the message is often scaled to a real world value. Typically this is provided as a multiplier and adder value, but may also specify a divider.
Big Endian or Little Endian mode
  • Decimal value: 1000
  • Hex Value in Big Endian: 0x03E8
  • Hex Value in Little Endian: 0xE803
MSB format:
  • Offset 1
  • Length 2
  • Data:
(Hex)     [xx] [03] [E8] [xx] [xx] [xx] [xx] [xx]
(Decimal) [xx] [3] [232] [xx] [xx] [xx] [xx] [xx]
LSB format:
  • Offset 1
  • Length 2
  • Data:
(Hex)     [xx] [E8] [03] [xx] [xx] [xx] [xx] [xx]
(Decimal) [xx] [232] [3] [xx] [xx] [xx] [xx] [xx]
Enabling CAN bus
Mapping CAN data to channels
Direct CAN mapping
Adding a channel
  • To start, connect to your RaceCapture device and ensure the current configuration is read, or open a previously saved configuration.
  • Navigate to the CAN Mapping page.
  • Ensure CAN channels is set to on
  • Press the (+) button to add your first channel.
Defining the Channel
  • Channel Name: selecting a channel name from the drop-down will pre-set the units, min, max and precision to typical values.
You can customize this by pressing the gear icon to customize:
    • Channel Name - Specify the channel name. We recommend formatting the name with CamelCase with a leading capital letter, and no spaces or underscores.
    • Units - The unit of measurement for the channel
    • Min - The minimum value for the channel
    • Max - The maximum value for the channel
    • Precision - Sets the number of decimal places for logged and displayed numbers.
  • Rate: This sets the rate that RaceCapture will log or broadcast the data for this channel. This rate is independent of the actual rate the CAN data is received. Select a rate that mirrors the expected update rate of the sensor. Example: Engine temperature changes slowly, so select 1Hz. RPM changes quickly; 10-50Hz is ideal.
Defining the CAN ID and bus
  • CAN ID: this is the ID of the CAN bus message, in decimal format.
  • Mask: This is an optional mask, in decimal format. If set to greater than zero, the Mask will be logically AND'd with the CAN ID for further matching and filtering.
    • If uncertain, leave this unchanged
  • Sub ID: If the CAN message specifies the first byte as an additional ID to differentiate messages, specify the value to match here.
  • CAN Bus: Select the CAN bus your data is appearing on - CAN 1 or 2, depending on the available CAN ports of your RaceCapture device.
Defining the mapping
  • Offset: this is the offset where the data appears in the CAN message. An offset of 0 would be used to start at the first byte of the CAN message.
  • Length: this represents the length of the value. A length of 1 would be one byte, 2 would represent a two byte or 16 bit word, and so on.
  • Source Type: this represents the native encoding of the data. Most typically this is represented as a plain unsigned value, but can appear in other formats. The manufacturer's CAN documentation will identify the data type. Supported native data types:
    • Unsigned: the data is provided as an unsigned value.
    • Signed: the data is provided as a two's compliment signed value.
    • Float: the data is provided as a IEEE-754 encoded floating point value
    • Sign-Magnitude: the data is provided as a sign-magnitude encoded value.
  • Endian: This defines Big Endian (Most significant bit / MSB) or Little Endian (Least Significant Bit / LSB) mode, and applies to values where the data length is 2 or higher. The manufacturer's documentation will identify whether the data is encoded in big or little endian format.
  • Bit Mode: This allows mapping in cases where the data does not fall on even byte boundaries. For example, you may want to extract a single bit at the offset of 11; in which case you would enable bit mode, then set your offset to 11 with a length of 1.
    • If uncertain, leave this unchecked, or check the manufacturer's documentation
Defining the Formula
Units Conversion
You can optionally apply a common units conversion to the value after it has been processed by the formula. Often the manufacturer will provide the mapping in one form of units - this allows you to retain the original mapping and then convert the units to the desired format.
Testing your channel
Not getting the expected data?
Lua scripting
  • Applies to:
    • RaceCapture/Pro MK2 and newer
    • RaceCapture/Apex
    • RaceCapture/Track MK2 and newer
Reading a CAN message
id, ext, data = rxCAN(0, 100)
Mapping to a Virtual Channel
  • Set up the channel. Example "EngineTemp"
  • Read a CAN message
  • Extract a value from the data fields
  • Scale the extracted value to a real world value (Example: Degrees F)
  • Set the virtual channel with the scaled value
  • Example: Set MyChannel from CAN ID 1234. Data is in the first byte of the message.
   id, ext, data = rxCAN(0)
   if id == 1234 then
CAN integration framework
tickRate = 30
--the CAN baud rate
CAN_baud = 500000
CAN_chan = 0
be_mode = 0
CAN_map = {
    processCAN(CAN_chan)
function processCAN(chan)
    repeat
            local map = CAN_map[id]
            if map ~= nil then
                map(data)
    until id == nil
    offset = offset + 1
    local value = 0
    local shift = 1
    while len > 0 do
        shift = shift * 256
        offset = offset + 1
        len = len - 1
    offset = offset + 1
    local value = 0
    while len > 0 do
        offset = offset + 1
        len = len - 1
initCAN(CAN_chan, CAN_baud)
Reverse Engineering
Common Approach
  • Log all messages from the CAN bus
  • Directly measure or observe a sensor channel and compare it against changes in the CAN bus data, watching for patterns.
Example
Logging Data
Check the CAN bus settings
  • Ensure the global CAN enabled option is turned 'on on the CAN settings page
  • Ensure the baud rate matches the network you're connecting to.
    • If you're not certain, check the documentation of the device you're integrating with (ECU, sensor network, etc)
  • Ensure the CAN termination is correct for the network you are on.
    • Termination is required at both ends of the network; check your manufacturer if termination is enabled inside the device, or if an external jumper is needed.
    • Note:
      • RaceCapture/Pro MK3, RaceCapture/Apex, PodiumConnect, RaceCapture/Track MK3: Termination is software controlled; enabled by default. It can be enabled/disabled in the CAN Bus settings page.
      • RaceCapture/Pro MK2 has termination enabled by default, it can be disabled by disabling the internal jumper
      • RaceCapture/Track (MK1, MK2) - Termination is disabled by default. Termination can be enabled by enabling an internal jumper.
Check the CAN activity LED
The CAN activity LED will indicate if CAN data is being received by your RaceCapture system. If it's illuminated, that means RaceCapture is receiving CAN data.
  • Applies to:
    • RaceCapture/Apex
    • RaceCapture/Track (MK3 and MK4)
    • PodiumConnect MK2
    • PodiumConnect/Micro
Check the CAN bus you are using (CAN1 or CAN2)
If you're using a preset, check if the CAN bus you wired matches the CAN bus selected for each channel in the preset.
  • Most presets are configured to use CAN1. If you wired your CAN but to CAN2, you will need to switch each channel under presets to CAN2.
Check the wiring
  • Ensure you have CAN High and CAN Low of the other CAN device wired to the equivalent CAN high and CAN low of RaceCapture.
    • If the wires are reversed, try swapping them.
  • Check that you have the wires connected correctly per the pinout of your system.
Check termination on the bus
Ideally, you should have termination at each end of the bus. Due to the robustness of CAN bus, often termination at one end of the bus is sufficient for correct data transmission.
    • RaceCapture/Pro, RaceCapture/Apex and PodiumConnect: Software-controlled termination can be accessed under Setup/CAN bus.
    • RaceCapture/Track MK1 and MK2 have no termination on board - termination can be added near the connector.
Ensure that the device at the opposite end of the CAN bus has termination enabled.
  • To enable termination, connect a 120 ohm resistor (1/8 to 1/4 W) across the CAN high and CAN low wires.
Check the other device
Ensure the setup is correct on the device. Check their manual and software to ensure:
  • CAN broadcasting is enabled
  • CAN baud rate matches the CAN baud rate your system
    • Typical baud rates are 250K, 500K and 1M
  • CAN IDs match the IDs you have defined under the CAN channels.
    • Some devices have the ability to set an alternate addressing scheme; their documentation will indicate if this is possible.
    • Use the simple logging script to display all CAN traffic in the logging window to see if what you are receiving is what you expect.
CAN bus logger
  • Try using the simple logging script to show any incoming data and that it matches what you expect vs the manufacturer's specifications.
