BMW E46 CAN
Things you'll need
- Crimp tool
- Wire cutter
- Wire stripper
- Philipps screwdriver
- Multimeter
- 22 gauge solid wire
- RJ 45 (Ethernet) cable, ~6ft
- Shrink tubing (optional, electrical tape will work too, but not look as nice)
- Posi-tap connectors (2) - Do *not* cut the CAN wires during this installation, use wire taps (Posi-taps work very well)
- Butt connectors (2) for 22 gauge wire
- Flashlight
- RaceCapture/Pro with Bluetooth
- Android tablet
- An E46 ;)
Estimated Time
2-3 hours, depending on level of wiring experience. The most time consuming part is splicing the CAN, power and ground wires into
Step 1: CAN wires
- Yellow/Brown = CAN- (low)
- Yellow/Red = CAN+ (high)
Remove bottom of dash
Locate CAN wires
Tapping CAN wires
Step 2: Power and ground wiring
Locate power and ground wires
Splice power and ground wires
Step 3: Build CAN cable
Step 4: Configure RaceCapture/Pro
Enable the CAN bus in your RaceCapture/Pro configuration as shown here: http://www.autosportlabs.net/RaceCapturePro2_OBD2#Enable_CAN_bus
Do *not* enable OBD-II channels.
coolantId = addChannel("Coolant", 10) oilId = addChannel("OilTemp", 10) throttleId = addChannel("TPS", 10) brakeId = addChannel("Brake", 10) setTickRate(30) function onTick() repeat id, ext, data = rxCAN(0) if id == 809 then temperatureC = (data[2] * 0.75) - 48.373 temperatureF = (temperatureC*1.8)+32 setChannel(coolantId, temperatureF) throttle = data[6]/255 setChannel(throttleId, throttle) brake = data[7] setChannel(brakeId, brake) end if id == 1349 then temperatureC = data[5] - 48.373 temperatureF = (temperatureC*1.8)+32 setChannel(oilId, temperatureF) end until id == nil end
Step 5: Test!
If you are still having issues post your problem on the forums here http://www.autosportlabs.org/viewforum.php?f=20&sid=88ccc8d4a459a907c2b8f951f6b3d103
Additional resources
- http://aimsportsystems.com.au/download/ecu/stock/bmw/BMW_Mini_100_eng.pdf - AIM docs for e46 M3 CAN codes
- http://www.diyelectriccar.com/forums/showthread.php/my-can-bus-gauge-solution-bmw-84882.html
- http://www.beisansystems.com/misc/SEIMENS_MS_420_ENGINE_CONTROL_SYSTEM.pdf
- http://www.bmwtech.ru/pdf/e46/ST034/2%20Driver%20Information%20Internet-1.pdf
- http://www.gadgetgangster.com/news/54-new-projects/556-the-car-kracker.html
- http://www.reslers.de/IBUS/index.html
- http://www.bimmerforums.com/forum/showthread.php?1887229-E46-Can-bus-project
- http://forum.e46fanatics.com/showpost.php?p=15754605&postcount=5
