CAN bus mappings by OEM ECU and aftermarket device
AIM Smarty CAM CAN protocol
Installation instructions
- Baud Rate: 1MB (Configurable in Megasquirt)
- Values in little endian format
| AIM Smarty CAM protocol
| Channel
Units
CAN Id
Offset (bytes)
Length (bytes)
Multiplier
Adder
Notes
| RPM
1056
0
2
1
0
| EngineTemp
C
1056
6
2
0.1
0
| OilTemp
C
1057
4
2
0.1
0
| OilPress
Bar
1057
6
2
0.01
0
| TPS
1058
2
1
1
0
| Fuel
L
1070
0
1
1
0
Megasquirt CAN ( MS2/MS3/MS3 Pro )
| Megasquirt CAN (Dashboard Mode)
| Channel
Units
CAN Id
Offset (bytes)
Length (bytes)
Conversion
Notes
| In development
| Megasquirt CAN (standard mode)
| Channel
Units
CAN Id
Offset (bytes)
Length (bytes)
Conversion
Notes
| RPM
1520
6
2
(B6 * 256) + B7
| IgnTiming
Degrees
1521
0
2
((B0 * 256) + B1) / 10
| AFR
AFR
1521
4
2
((B4 * 256) + B5) / 10
Legacy AFR1 (Deprecated on MS3) - to use AFR2 specify offset 6
| MAP
kPa
1522
2
2
((B2 * 256) + B3) / 10
| MAT
F
1522
4
2
| EngineTemp
F
1522
6
2
((B6 * 256) + B7) / 10
| TPS
1523
0
2
| EngineTemp
F
1522
6
2
| Knock
1524
0
2
Indication of knock input
| AFR
1551
0
1
B0 / 10
AFR for cylinder #1 (MS3+ compatible) - add 1 to offset for subsequent AFR inputs
BMW E46
- Baud Rate: 500K
- Little Endian Format
| BMW E46 (including M3)
| Channel
Units
CAN Id
Offset (bytes)
Length (bytes)
Conversion
Notes
| TPS
809
6
1
(B6 / 255)
| EngineTemp
C
809
2
1
(B2 * 0.75) - 48.373
Convert to Farenheight: (temperatureC * 1.8) + 32
| OilTemp
C
1349
5
1
B5 - 48.373
| RPM
790
3-4
1
((B4 * 256) + B3) / 6.4
Mini Cooper R53
- Baud Rate: 500K
| Mini Cooper R53
| Channel
Units
CAN Id
Offset (bytes)
Length (bytes)
Conversion
Notes
| TPS
809
6
1
(B6 / 254) * 100
| EngineTemp
C
809
2
1
| RPM
790
3-4
1
MBE Systems 992
- Baud Rate: ???
- Little Endian format
| MBE Systems 992 (Locked Caterham mode)
| Channel
Units
CAN Id
Offset (bytes)
Length (bytes)
Conversion
Notes
| EngineTemp
C?
814
0
1
B0
Need to verify scaling and temperature units
| RPM
814
1
2
(B2 * 256) + B1
| TPS
814
3
0
B0 / 5.0
Outputs as throttle voltage. assuming a 0-5v system, scale by 5v
| OilPress
PSI?
815
2
1
B2
Need to verify scaling and Pressure units
| OilTemp
C?
815
3
1
B3
