BMW E46 CAN
Things you'll need
- Crimp tool
- Wire cutter
- Wire stripper
- Philipps screwdriver
- Multimeter
- 22 gauge solid wire
- RJ 45 (Ethernet) cable, ~6ft
- Shrink tubing (optional, electrical tape will work too, but not look as nice)
- Posi-tap connectors (2) - Do *not* cut the CAN wires during this installation, use wire taps (Posi-taps work very well)
- Butt connectors (2) for 22 gauge wire
- Flashlight
- RaceCapture/Pro with Bluetooth
- Android tablet
- An E46 ;)
Estimated Time
CAN wires
- Yellow/Brown = CAN- (low)
- Yellow/Red = CAN+ (high)
Remove bottom of dash
Locate CAN wires
Tapping CAN wires
Power and ground wiring
Mk1 owners: do not wire in power or ground.
Locate power and ground wires
Splice power and ground wires
Connect CAN cable
Step 4: Configure RaceCapture/Pro
- Rate is 500kb/s
- Do not enable OBD-II channels.
--This example configured for E46 CAN -- Automatically starts logging with engine 'on' (RPM triggered) --how frequently we poll for CAN messages tickRate = 30 --the CAN baud rate CAN_baud = 500000 --CAN channel to listen on. 0=first CAN channel, 1=second CAN_chan = 0 --1 for Big Endian (MSB) mode; 0 for Little Endian mode (LSB) be_mode = 0 --add your virtual channels here tpsId = addChannel("TPS", 10, 0, 0, 100, "%") tempId = addChannel("EngineTemp", 1, 0, 0, 200, 'C') oilTempId = addChannel("OilTemp", 1, 0, 0, 200, 'C') rpmId = addChannel("RPM", 10, 0, 0, 10000) function steerFilter(value) if value > 32768 - 1 then value = value - 32768 end return value end --Convert C to F function toF(value) return value * 1.8 + 32 end --E46 TPS, because 100% throttle actually returns 86% function e46_tps(value) return value * 1.16 end --only start logging / telemetry if engine is running function rpmFilter(value) if value > 500 then startLogging() else stopLogging() end return value end ---------------------------------------- --customize here for CAN channel mapping --format is: --[CAN Id] = function(data) map_chan(<chan_id>, data, <CAN offset>, <CAN length>, <multiplier>, -- <adder>, [filter]) ---------------------------------------- CAN_map = { [809] = function(data) map_chan(tpsId, data, 5, 1 , 0.392156863, 0, e46_tps) map_chan_le(tempId, data, 1, 1, 0.562, -48, toF) end, [1349] = function(data) map_chan(oilTempId, data, 4, 1, 0.8117, -48, toF) end, [790] = function(data) map_chan(rpmId, data, 2, 2, 0.15625, 0, rpmFilter) end } function onTick() processCAN(CAN_chan) end --===========do not edit below=========== function processCAN(chan) repeat local id, e, data = rxCAN(chan) if id ~= nil then local map = CAN_map[id] if map ~= nil then map(data) end end until id == nil end --Map CAN channel, little endian format function map_chan_le(cid, data, offset, len, mult, add, filter) offset = offset + 1 local value = 0 local shift = 1 while len > 0 do value = value + (data[offset] * shift) shift = shift * 256 offset = offset + 1 len = len - 1 end local cv = (value + add) * mult if filter ~= nil then cv = filter(cv) end setChannel(cid, cv) end --Map CAN channel, big endian format function map_chan_be(cid, data, offset, len, mult, add, filter) offset = offset + 1 local value = 0 while len > 0 do value = (value * 256) + data[offset] offset = offset + 1 len = len - 1 end local cv = (value + add) * mult if filter ~= nil then cv = filter(cv) end setChannel(cid, cv) end map_chan = (be_mode == 1) and map_chan_be or map_chan_le initCAN(CAN_chan, CAN_baud) setTickRate(tickRate)�
Test!
Real-Time Telemetry!
Just 4 wires - Power, Ground, CAN+ and CAN- is needed to stream tons of data to race-capture.com for monitoring engine, driver and suspension performance!
If you are still having issues post your problem on the forums here http://www.autosportlabs.org/viewforum.php?f=20&sid=88ccc8d4a459a907c2b8f951f6b3d103
CAN Channel Mapping
Additional resources
- http://aimsportsystems.com.au/download/ecu/stock/bmw/BMW_Mini_100_eng.pdf - AIM docs for e46 M3 CAN codes
- http://www.diyelectriccar.com/forums/showthread.php/my-can-bus-gauge-solution-bmw-84882.html
- http://www.beisansystems.com/misc/SEIMENS_MS_420_ENGINE_CONTROL_SYSTEM.pdf
- http://www.bmwtech.ru/pdf/e46/ST034/2%20Driver%20Information%20Internet-1.pdf
- http://www.gadgetgangster.com/news/54-new-projects/556-the-car-kracker.html
- http://www.reslers.de/IBUS/index.html
- http://www.bimmerforums.com/forum/showthread.php?1887229-E46-Can-bus-project
- http://forum.e46fanatics.com/showpost.php?p=15754605&postcount=5
