Hondata KPro4
Revision as of 18:40, 9 October 2015 by Brentp (talk | contribs) (updated with latest.)
The following script adapts the Hondata KPro4 CAN to RaceCapture/Pro
--This example adopted to Hondata KPro4 CAN output
--how frequently we poll for CAN messages, 30Hz is the max
tickRate = 30
--the CAN baud rate
CAN_baud = 250000
CAN_chan = 0
be_mode = 1
function toF(value)
 return value * 1.8 + 32
function toAFR(value)
 return value * 14.7
CAN_map = {
[1632] = function(data)
  map_chan(rpmId, data, 0, 2, 1, 0)
  map_chan(speedId, data, 2, 2, 0.621371, 0)
  map_chan(vltId, data, 5, 1, 0.1, 0)
end,
[1633] = function(data)
  map_chan(iatId, data, 0, 2, 1, 0, toF)
  map_chan(ectId, data, 2, 2, 1, 0, toF)
end,
[1634] = function(data)
  map_chan(tpsId, data, 0, 2, 1, 0)
  map_chan(mapId, data, 2, 2, 0.1, 0)
end,
[1635] = function(data)
  map_chan(injId, data, 0, 2, 0.001, 0)
  map_chan(ignId, data, 2, 2, 1, 0)
end,
[1636] = function(data)
  map_chan(afrId, data, 0, 2, 0.00003051757, 0, toAFR)
end,
[1637] = function(data)
  map_chan(knkId, data, 0, 2, 1, 0)
end,
[1638] = function(data)
  map_chan(camId, data, 2, 2, 1, -20)
end,
[1639] = function(data)
  map_chan(anv1Id, data, 0, 2, 4096, 0)
  map_chan(anv2Id, data, 2, 2, 4096, 0)
  map_chan(anv3Id, data, 0, 4, 4096, 0)
  map_chan(anv4Id, data, 0, 6, 4096, 0)
end,
[1640] = function(data)
  map_chan(anv5Id, data, 0, 2, 4096, 0)
  map_chan(anv6Id, data, 2, 2, 4096, 0)
  map_chan(anv7Id, data, 0, 4, 4096, 0)
  map_chan(anv8Id, data, 0, 6, 4096, 0)
rpmId = addChannel("RPM", 25, 0, 0, 9000, "RPM")
speed_id = addChannel ("RoadSpeed", 5, 0, 0, 200, "MPH")
vltId = addChannel("EcuVolts", 10, 1, 0, 20, "volts")
iatId = addChannel("IAT", 1, 1, 0, 100, "C")
coolantId = addChannel("Coolant", 1, 1, -30, 400, "F")
tpsId = addChannel("TPS", 10, 1, 0, 100, "%")
mapId = addChannel("MAP", 10, 1, 0, 15, "PSI")
injId = addChannel("InjectorPW", 10, 3, 0, 100, "ms")
ignId = addChannel("IgnTiming", 10, 1, -20, 20, "D")
afrId = addChannel("AFR", 10, 1, 5, 40, "AFR")
knkId = addChannel("Knock", 1, 0, 0, 15, "count")
camId = addChannel("CamTiming", 10, 1, -40, 40, "D")
anv1Id = addChannel("Anv1", 1, 2, 0, 5, "V")
anv2Id = addChannel("Anv2", 1, 2, 0, 5, "V")
anv3Id = addChannel("Anv3", 1, 2, 0, 5, "V")
anv4Id = addChannel("Anv4", 10, 2, 0, 5, "V")
anv5Id = addChannel("Anv5", 1, 2, 0, 5, "V")
anv6Id = addChannel("Anv6", 10, 2, 0, 5, "V")
anv7Id = addChannel("Anv7", 1, 2, 0, 5, "V")
anv8Id = addChannel("Anv8", 1, 2, 0, 5, "V")
    processCAN(CAN_chan)
function processCAN(chan)
    repeat
            local map = CAN_map[id]
            if map ~= nil then
                map(data)
    until id == nil
function map_chan_le(cid, data, offset, len, mult, add, filter)
    offset = offset + 1
    local value = 0
    local shift = 1
    while len > 0 do
        shift = shift * 256
        offset = offset + 1
        len = len - 1
 local cv = (value + add) * mult
    setChannel(cid, cv)
function map_chan_be(cid, data, offset, len, mult, add, filter)
    offset = offset + 1
    local value = 0
    while len > 0 do
        offset = offset + 1
        len = len - 1
    setChannel(cid, cv)
initCAN(CAN_chan, CAN_baud)
