BMW E46 CAN
Revision as of 19:08, 23 January 2016 by Brentp (talk | contribs) (cleaned up and adjusted to prevent Lua runtime crash observed in 2.8.7 with previous script version. moved steering processing outside of channel mapping.)
Things you'll need
  • Crimp tool
  • Wire cutter
  • Wire stripper
  • Philipps screwdriver
  • Multimeter
  • 22 gauge solid wire
  • Flashlight
  • Android tablet
  • An E46 ;)
Estimated Time
CAN wires
  • Yellow/Red = CAN+ (high)
  • Yellow/Brown = CAN- (low)
Remove bottom of dash
Locate CAN wires
Tapping CAN wires
Power and ground wiring
Option #1: OBD-II port power
CAN High Yellow/Red Orange
Splice power and ground wires
CAN Bus connection
  • Orange: CAN1 High
  • Green/white: CAN1 Low
  • Brown: Power
  • Orange/white: Ground
Use the following diagram:
Configure RaceCapture/Pro
Quick Start E46 configuration
Download: E46 CAN starter configuration (right-click, save-as)
Manual Setup
  • Rate is 500kb/s
  • Do not enable OBD-II channels.
tickRate = 30
--the CAN baud rate
CAN_baud = 500000
CAN_chan = 0
tempId = addChannel("EngineTemp", 1, 0, 0, 255, 'F')
oilTempId = addChannel("OilTemp", 1, 0, 0, 255, 'F')
steerId = addChannel("Steering", 10, 0, -360, 360)
--Convert C to F
function toF(value)
 return value * 1.8 + 32
function e46_tps(value)
 return value - 0.0
function rpmFilter(value)
 return value
function processSteering(data)
    local steer = 0
    if data[2] > 127 then
    else
      steer = (data[2]*256)+data[1]
--format is:
--[CAN Id] = function(data) map_chan(<chan_id>, data, <CAN offset>, <CAN length>, <multiplier>,
--                                   <adder>, [filter])
CAN_map = {
[809] = function(data) map_chan(tpsId, data, 5, 1 , 0.392156863, 0, e46_tps) map_chan(tempId, data, 1, 1, 0.75, -48, toF) end,
[790] = function(data) map_chan(rpmId, data, 2, 2, 0.15625, 0, rpmFilter) end,
[501] = function (data) processSteering(data) end
    processCAN(CAN_chan)
function processCAN(chan)
    repeat
            local map = CAN_map[id]
            if map ~= nil then
                map(data)
    until id == nil
    offset = offset + 1
    local value = 0
    local shift = 1
    while len > 0 do
        shift = shift * 256
        offset = offset + 1
        len = len - 1
 local cv = value * mult + add
    setChannel(cid, cv)
initCAN(CAN_chan, CAN_baud)
Test!
Real-Time Telemetry
Just 4 wires - Power, Ground, CAN+ and CAN- is needed to stream tons of data to race-capture.com for monitoring engine, driver and suspension performance!
CAN Channel Mapping
Additional resources
