RaceCapturePro2 hardware guide
Revision as of 18:50, 21 December 2016 by Brentp (talk | contribs) (→Sensors)
Quick Reference
Download a printable PDF
Power Connection
Analog Inputs 1-7
  • Input Impedance: 1 megaohm
Active Sensors/Signals
Resistive sensor
Analog Calibration
Tapping into existing Sensors
Connection
Calibration
First, you will need to determine the 'voltage curve: You will need to know if the sensor responds linearly or on a curve.
Linear
    • If the sensor response is linear, then you will need to know just two points: the voltage at the low end of the gauge, and the voltage at the high end of the gauge.
0 PSI = 0 v 150 PSI = 4.5 volts
You would adjust the analog mapping to set the scale so that: 0 volts = 0 PSI and 4.5 volts = 150 PSI
Curved response
Thermistor-based temperature sensors typically will have a curved response. This is more complex to map, but RaceCapture/Pro offers the ability map multiple points across this curve, with the ability to linearly interpolate between points.
As the sensor's temperature, pressure (or whatever the sensor is reading) rises, the voltage sensed may increase, or reduce. Use the manufacturer's specifications to map these values into the Analog sensor configuration. If you do not have the manufacturer's specifications, you will need to take voltage readings across the range of the sensor.
  • The default calibration value is 1.0 - you can adjust it up or down to fine tune to match your electrical system.
  • When configured for input, the channel accepts a 0-5v input (protected up to 400V).
  • When configured for output, the channel provides an open-drain output that can drive 1A and is thermal / over-current protected with inductive load clamping.
Frequency/Pulse Input 1 - 3
TACH SIGNAL NOTES
CoilX Sensor Module
CAN bus port
  • See the quick reference guide for pinout
SD Card Slot
USB Port
LED Indicators
  • Power LED
  • GPS LED
  • Logging LED
  • Telemetry LED
Indicates telemetry activity.
    • A slow flash interval indicates connection initialization
    • A regular flash matching the highest logging rate (up to 10Hz) indicates connected and streaming
Pushbutton
  • Note this may be overridden by any on-board scripts that may automatically start or stop logging.
Communication Ports
  • Ext Telemetry / Bluetooth - Used for Bluetooth module
  • Auxiliary port - used for integrating external systems / devices
GPS port
  • Tighten this to 3-5 inch/lbs. This connection should be snug.
  • To prevent damage to the connector, do not over-tighten
Telemetry port
Physical Installation
  • Dimensions: 5.3" (width) x 4.2" (height) x 1.2" (tall) / 135x110x31 mm(est)
  • Mounting area: 5.5"(140mm) x 4"(102mm)
  • Mounting fasteners: Dual mounting points on 5" (127mm) centers - 0.125"-0.25" (3-6mm) fastener
Shock isolation mounting
