BMW E46 Guide
Revision as of 15:01, 17 August 2019 by Brentp (talk | contribs)
BMW E46 (1999 to 2007)
CAN bus integration
RaceCapture/Pro can integrate with the E46 proprietary (non OBD-II) CAN bus network. Additional sensors for data not provided by the CAN bus connection can connected via direct inputs.
Direct Sensors
Oil Pressure
You can tap into the engine TD/RPM signal from Pin 9 of the OBD-II port, available on all BMWs after 2000.
RaceCapture/Pro Timer Configuration
  • Timer Speed: Medium
  • Pulse Per Revolution: 3
Brake Pressure
You can tap into brake pressure by accessing the signals in the ECU box.
  • Front pressure: Black/Violet/Yellow
  • Rear Pressure: Black/Violet
