BMW E36 Guide
Revision as of 19:15, 21 March 2016 by Brentp (talk | contribs) (Fuel Level)
BMW E36 (1990 - 1999)
  • Timer Mode: RPM
  • Timer Speed: Medium
  • Pulse Per Revolution: 3
Engine Temperature
In research
Fuel Level
In research
(Needs verification)
  • 0 ohms empty
  • ?? ohms 1/4
  • ?? ohms 1/2
  • ?? ohms 3/4
  • 260 ohms full
Oil Pressure
External Reference
