BMW E46 CAN
Revision as of 22:26, 20 November 2018 by Brentp (talk | contribs)
Required parts
Pre-made E46 integration cable
If you want a ready made cable, you can order one from our online store
DIY Cable
  • Crimp tool
  • Wire cutter
  • Wire stripper
  • Philipps screwdriver
  • Multimeter
  • 22 gauge solid wire
  • Flashlight
  • Android tablet
  • An E46 ;)
Estimated Time
CAN wires
  • Yellow/Red = CAN+ (high)
  • Yellow/Brown = CAN- (low)
Remove bottom of dash
Locate CAN wires
Tapping CAN wires
Power and ground wiring
Option #1: OBD-II port power
CAN High Yellow/Red Orange
Splice power and ground wires
CAN Bus connection
  • Orange: CAN1 High
  • Green/white: CAN1 Low
  • Brown: Power
  • Orange/white: Ground
Use the following diagram:
Configure RaceCapture/Pro
Set Baud Rate
E46 CAN bus Preset
Verifying real-time data
Additional resources
