Hondata KPro4
Revision as of 16:12, 20 July 2016 by Brentp (talk | contribs) (Script)
The following script adapts the Hondata KPro4 CAN to RaceCapture/Pro
Supported Channels
This integration supports the following channels:
  • RPM
  • EcuVolts
  • IAT
  • EngineTemp
  • TPS
  • MAP
  • InjectorPW
  • Ignition
  • Knock
  • CamTiming
Use the supplied Hondata harness and connect the CAN High / CAN Low to the corresponding CAN High / CAN Low on the RaceCapture/Pro CAN 1 channel. See the [CAN_Bus_Integration|CAN integration guide]] for wiring details.
CAN termination
The KPro4 does not have built-in CAN termination. You will need to also connect a 120 ohm resistor across the CAN High / CAN Low connections at the connections to the KPro4.
Script
Copy and paste this script into the scripting window of RaceCapture/Pro. Ensure any existing script is removed.
--This example adopted to Hondata KPro4 CAN output
tickRate = 30
--the CAN baud rate
CAN_baud = 250000
CAN_chan = 0
rpmId = addChannel("RPM", 25, 0, 0, 9000, "RPM")
vltId = addChannel("EcuVolts", 10, 1, 0, 20, "volts")
iatId = addChannel("IAT", 1, 0, 0, 100, "F")
ectId = addChannel("EngineTemp", 1, 0, 0, 150, "F")
mapId = addChannel("MAP", 10, 2, -15, 25, "PSI")
injId = addChannel("InjectorPW", 10, 3, 0, 100, "ms")
ignId = addChannel("Ignition", 10, 0, -20, 20, "D")
lmdId = addChannel("AFR", 10, 3, 0, 2, "lambda")
knkId = addChannel("Knock", 1, 0, 0, 15, "count")
camId = addChannel("CamTiming", 10, 0, -20, 20, "D")
function toF(value)
 return value * 1.8 + 32
function toAFR(value)
 return value * 14.7
--offset/length in bytes?
CAN_map = {
--did not bother logging gear speed and target cam angle
[1632] = function(data) map_chan(rpmId, data, 0, 2, 1, 0) map_chan(vltId, data, 5, 1, 0.1, 0) end,
[1633] = function(data) map_chan(iatId, data, 0, 2, 1, 0, toF) map_chan(ectId, data, 2, 2, 1, 0, toF) end,
[1634] = function(data) map_chan(tpsId, data, 0, 2, 1, 0) map_chan(mapId, data, 2, 2, 0.0145037738, -14.7) end,
[1635] = function(data) map_chan(injId, data, 0, 2, 0.001, 0) map_chan(ignId, data, 2, 2, 1, 0) end,
[1636] = function(data) map_chan(lmdId, data, 0, 2, 0.00003051757, 0, toAFR) end,
[1637] = function(data) map_chan(knkId, data, 0, 2, 1, 0) end,
[1638] = function(data) map_chan(camId, data, 2, 2, 1, 0) end
 processCAN(CAN_chan)
 processLogging()
function processLogging()
 if getGpio(1) < 1 then
   startLogging()
 else
   stopLogging()
function processCAN(chan)
    repeat
            local map = CAN_map[id]
            if map ~= nil then
                map(data)
    until id == nil
    offset = offset + 1
    local value = 0
    while len > 0 do
        offset = offset + 1
        len = len - 1
	local cv = value * mult + add
    setChannel(cid, cv)
initCAN(CAN_chan, CAN_baud)
