RaceCapture-Track
Revision as of 00:39, 16 November 2016 by Brentp (talk | contribs) (→How it works)
Start it up
Plug it in
Download the app
Navigating dashboard screens
Setup Mode
You can configure RaceCapture simultaneously for both Access Point and Client mode.
Telemetry
Logs
Analysis Mode
Applying Decals
