RaceCapture-Track
Revision as of 05:35, 16 November 2016 by Brentp (talk | contribs) (→Accel / Gyro)
Start it up
Plug it in
Download the app
Navigating dashboard screens
Setup Mode
Telemetry
Logs
Analysis Mode
RaceCapture will automatically record your session in the background while in dashboard mode. To view the data, enter the Analysis mode and load an existing session. The session will be automatically named with the track or with a timestamp.
Navigating data
Selecting Time vs Distance
Applying Decals
