RaceCapture-Track
Start it up
Plug it in
Download the app
- Google Play
- Amazon App Store
Setup Mode
- Note: Whenever you make a change on one of these pages, you will need to write your changes back to the RaceCapture device.
- Common baud rates for OBDII is 500K and 250K. The default is 500K, which applies to nearly every CAN OBDII vehicle.
- Note about unsupported channels: - If your ECU does not support a channel, the value will remain at 0. RaceCapture will time-out waiting for a response from the ECU, which will affect the performance of other channels. We recommend removing all unsupported channels to ensure optimal OBDII performance.
<img src="
" width="500"/>
Enabling Telemetry
Logs
Analysis Mode
Selecting Time vs Distance
Applying Decals
