RaceCapture-Track
Revision as of 08:07, 16 November 2016 by Brentp (talk | contribs) (→System Status)
Start it up
Plug it in
Download the app
Navigating dashboard screens
Setup Mode
Enabling Telemetry
Logs
Analysis Mode
Navigating data
Selecting time vs distance
Applying Decals
