RaceCapture-Track
Start it up
Plug it in
Download the app
- Google Play
- Amazon App Store
Setup Mode
- Note: Whenever you make a change on one of these pages, you will need to write your changes back to the RaceCapture device.
<img src="" width="640"/>
Enabling Telemetry
Logs
Analysis Mode
Selecting time vs distance
Applying Decals
More
Alternative ways to power
USB
Custom Cable
Connection | RaceCapture/Pro (RJ45 cable) |
+12v | Brown |
Ground | Orange/White |
CAN 1 High | Orange |
CAN 1 Low | Green/White |
