RacecapturePro MK3 hardware install
Mounting Orientation
Alternative Mounting
- Example:
- Upside down
- Vertical / on edge
Main Connector
Power | |
Connection | Color |
12v | Red |
Ground | Black |
Frequency / RPM sensor inputs | |
Blue | Frequency / RPM input 1 |
Blue / White stripe | Frequency / RPM input 2 |
Blue / Green Stripe | Frequency / RPM input 3 |
Blue / Orange Stripe | Frequency / RPM input 4 |
Voltage Reference | |
Yellow | +5v reference |
Analog Sensor Inputs | |
White | Analog Input 1 |
White / Black Stripe | Analog Input 2 |
White / Orange Stripe | Analog Input 3 |
White / Blue Stripe | Analog Input 4 |
White / Gray Stripe | Analog Input 5 |
White / Green Stripe | Analog Input 6 |
White / Red Stripe | Analog Input 7 |
White / Brown Stripe | Analog Input 8 |
General Purpose Input / Output (GPIO) | |
Gray | GPIO 1 |
Gray / White Stripe | GPIO 2 |
Gray / Blue Stripe | GPIO 3 |
Auxiliary Serial Input | |
Purple / White Stripe | Auxiliary RS232 Serial TX |
Purple | Auxiliary RS232 Serial RX |
CAN Bus | |
Orange / Blue Stripe | CAN 1 High |
Orange | CAN 1 Low |
Orange / Green Stripe | CAN 2 High |
Orange / White Stripe | CAN 1 Low |
Plug Connector Type
- Compatible Pins: Molex 46018-1541 or 46018-1541
- ProTip: a 24 pin Molex harness from a computer power supply can also work as a secondary wiring harness.
Cellular Telemetry
Antenna Placement Guide
Cellular antenna
Antenna separation
RJ45 CAN + Power connection
OBDII CAN cable
Custom Cable
Connection | CAT5 EIA-T568B RJ45 cable |
+12v | Brown |
Ground | Orange/White |
CAN 1 High | Orange |
CAN 1 Low | Green/White |
CAN 2 High | Blue |
CAN 2 Low | Blue/White |
Analog Sensor inputs
Voltage Range | 0-5v |
Input Impedance | Greater than 1M ohm |
Voltage protection | 400v (intermittent) |
ADC precision | 12 bit SAR |
Maximum Sample Rate | 1000Hz (logging to SD card) |
Mapping supported | Raw voltage / linear formula / interpolated map |
Connecting Sensors
Voltage Range | 0-12v |
Mapping supported | RPM / Frequency / Period |
Signal input quality
Special note about RPM inputs
If your only source for RPM is the trigger wire driving the ignition coil primary winding, then you will need the CoilX module to buffer / filter the noisy, high-voltage component.
Connecting Sensors
See our RaceCapturePro_RPM RPM connection guide for more information connecting and calibrating these frequency / RPM channels.
GPIO
Output mode type | Open Drain (connects ground when activated) |
Input voltage protection | 0-40v - inductive protection up to 1A |
Input Mode
Important Note: when sensing large inductive loads, such as sensing brake light state or sensing motor state, connect a 10K 1/4 watt resistor in-line with the GPIO input to protect RaceCapture/Pro from a very large inductive spike.
Output Mode
Output Behaviour
GPIO Connections
Controlling GPIO Ports
