BMW E36 Guide
Revision as of 17:49, 8 May 2017 by Brentp (talk | contribs) (→Road speed (differential speed sensor based))
BMW E36 (1990 - 1999)
- Timer Mode: RPM
- Timer Speed: Medium
- Pulse Per Revolution: 3
Engine Temperature
In research
Fuel Level
In research
(Needs verification)
- 0 ohms empty
- ?? ohms 1/4
- ?? ohms 1/2
- ?? ohms 3/4
- 260 ohms full
Oil Pressure
This calculates gear and speed based on the differential speed sensor. Assumes engine RPM is connected to the first RPM input.
- Pin 10 on radio connector
setTickRate(10) --10Hz --virtual channels --addChannel("name",SR,prec,min,max,"unit") speeddiff_id = addChannel("Speed_",10,0,0,160,"MPH") gear_id = addChannel("Gear_",5,0,0,5,"gear") --global constants --edit these to match your car first = 4.20 second = 2.49 third = 1.66 fourth = 1.24 fifth = 1.00 final = 3.46 tirediameter = 24.7 --global variables rpm = 0 rpm_diff = 0 speed = 0 function updateSpeedDiff() rpm_diff = getTimerRpm(1) speed = rpm_diff*tirediameter*0.002975 speed = speed + 0.5 -- round because 0 prec. truncates setChannel(speeddiff_id, speed) end function updateGear() rpm = getTimerRpm(0) local gearErr = 0.15 local gear = 0 if speed > 2 then ratio = rpm/(rpm_diff*final) if ((first - ratio)^2) < (gearErr^2) then gear = 1 end if ((second - ratio)^2) < (gearErr^2) then gear = 2 end if ((third - ratio)^2) < (gearErr^2) then gear = 3 end if ((fourth - ratio)^2) < (gearErr^2) then gear = 4 end if ((fifth - ratio)^2) < (gearErr^2) then gear = 5 end end setChannel(gear_id, gear) end function onTick() updateSpeedDiff() updateGear() end
