BMW E36 Guide
BMW E36 (1990 - 1999)
- Timer Mode: RPM
- Timer Speed: Medium
- Pulse Per Revolution: 3
TPS
- 0.62 volts at 0% throttle
- 4.64 volts at 100%
Configure a linear mapping in the analog input where the first bin is 0.62 volts / 100 scaled value; 2nd bin is 4.64 volts / 100 scaled value. Repeat the 2nd bin values for bins 3, 4 and 5.
Engine Temperature
In research
Should be similar to E30
Fuel Level
Mapping in RCP
- 0.2v = 0 (empty)
- 1.33v = 25 (1/4)
- 2.2v = 50 (half)
- 2.95v = 75 (3/4)
- 3.53v = 100 (full)
You may want to average your fuel readings to compensate for slosh.
(Needs verification)
- 0 ohms empty
- ?? ohms 1/4
- ?? ohms 1/2
- ?? ohms 3/4
- 260 ohms full
Oil Pressure
Assumes:
- Pin 10 on radio connector
setTickRate(10) --10Hz
--virtual channels
--global constants
first = 4.20
second = 2.49
third = 1.66
fourth = 1.24
fifth = 1.00
final = 3.46
tirediameter = 24.7
--global variables
rpm = 0
rpm_diff = 0
speed = 0
function updateSpeedDiff()
rpm_diff = getTimerRpm(1)
function updateGear()
rpm = getTimerRpm(0)
local gearErr = 0.15
local gear = 0
if speed > 2 then
ratio = rpm/(rpm_diff*final)
if ((first - ratio)^2) < (gearErr^2) then gear = 1 end
if ((third - ratio)^2) < (gearErr^2) then gear = 3 end
if ((fifth - ratio)^2) < (gearErr^2) then gear = 5 end
setChannel(gear_id, gear)
updateSpeedDiff()
updateGear()
