RaceCapturePro Lua Scripting
Revision as of 15:46, 11 January 2018 by Brentp (talk | contribs) (→getChannel( ))
Example Scripts and How-Tos
Lua Script Basics
Writing your script
onTick() function
Viewing the output log
Controlling the onTick() rate
count = 0
  count = count + 1
  println("Tick: " ..count)
Given:
  temperature = getAnalog(0)
  if temperature > 212 then
    setGpio(0, 1)
  else
    setGpio(0, 0)
Combining multiple functions
Example:
function checkTemps()
function checkAutoLogging()
  checkTemps()
  checkAutoLogging()
Debugging your script
Example:
    println("over temp!")
    setGpio(0, 1)
  else
    println("under temp")
    setGpio(0, 0)
Lua Reference
More examples
API Reference
getGpio( channel )
  • params
    • channel: integer 0 - 2
  • returns:
setGpio ( channel, state )
  • params
  • returns:
    • none
getButton()
  • params
    • none
  • returns
PWM / Analog Output functions
  • params
  • returns
    • none
setPwmClockFreq( frequency )
  • params
  • returns
    • none
  • params
    • returns
  • none
Timer / RPM Sensor Functions
getTimerRpm(channel)
  • params
    • returns: RPM value
getTimerPeriodMs(channel)
  • params
    • returns: millisecond value
getTimerFreq(channel)
  • params
    • returns: Frequency in Hz
getTimerRaw(channel)
  • params
Analog Sensor Functions
getAnalog(channel)
  • params
getImu(channel)
  • params
  • returns
getImuRaw(channel)
  • params
  • returns
    • The raw accelerometer value
GPS Sensor Functions
getGpsPos()
  • params
    • none
  • returns
getGpsSpeed()
  • params
    • (none)
  • returns
    • The current speed in MPH
getGpsQuality()
  • params
    • (none)
  • returns
getGpsSats()
  • params
    • (none)
  • returns
getGpsTime()
  • params
    • (none)
  • returns
    • The current GPS time value
getGpsDist()
  • params
    • (none)
  • returns
    • The distance, in Miles
getGpsAltitude()
  • Added: v2.9.0
  • Parameters: None
  • Returns: <altitude>
getLapCount()
  • params
    • (none)
  • returns
getLapTime()
  • params
    • (none)
  • returns
getPredTime()
as of 2.12.0 firmware
  • params
    • (none)
  • returns
getGpsSec()
  • params
    • (none)
  • returns
getAtStartFinish()
  • params
    • (none)
  • returns
getTimeDiff(time1, time2)
  • params
    • time1
    • time2
  • returns
getTimeSince(time)
  • params
    • time
  • returns
CAN Bus functions
initCAN(channel, baud )
  • params
  • returns
  • params
  • returns
Example:
channel = 0
id = 1234
ext = 0
data = {11,22,33}
rxCAN(channel, [timeout] )
  • params
  • returns
Example:
  • params
  • returns
readOBD2( PID )
  • params
  • returns
Logger Control Functions
onTick()
  • params:
    • (none)
  • returns:
    • (none)
Example:
setTickRate(rate)
  • params
  • returns
    • (none)
SD Logging control
isLogging()
  • params
    • (none)
  • returns
startLogging()
  • params
    • (none)
  • returns
    • (none)
stopLogging()
  • params
    • (none)
  • returns
    • (none)
setLed( led, state )
  • params
    • led (1-3)
  • returns
    • (none)
setBgStream( on/off )
  • params
  • returns
    • (none)
getBgStream()
  • params
    • (none)
  • returns
Serial Port Communications
Port mappings
0 = USB port
1 = GPS port
2 = Internal telemetry port (MK2/3/Apex only)
3 = Bluetooth port
4 = Auxiliary / WiFi port
5 = WiFi port 6 = External Auxiliary port (RaceCapture/Pro MK3 and RaceCapture/Apex only)
  • Note: We only recommend using ports 3 and 4 for connecting script to external devices. Ports 0 - 2 have been included for reference; using them may interfere with normal operations of the unit.
  • params
  • returns
readCSer( port, [timeout])
  • params
  • returns
readSer( port, [timeout])
  • params
    • port: Serial port 0 - 4
writeCSer( port, data )
  • params:
  • returns:
(no return values)
writeSer( port, data )
  • params
  • returns:
(no return values)
flashLoggerCfg()
  • params
    • (none)
  • returns
    • (none)
setPwmClockFreq( freq )
  • params
  • returns
    • (none)
getPwmClockFreq()
  • params
    • (none)
  • returns
calibrateImuZero()
  • params
    • (none)
  • returns
    • (none)
Virtual Channels
  • params
  • returns
  • Available in v2.9.0 ; retrieving by channel name available in v2.13.0
  • Parameters
    • Channel ID or name : if a number, matches on the channel ID as provided by the addChannel method. If string, matches on any current channel in the system.
  • Returns
    • (number) The current value of the channel.
  • Examples:
    • val = getChannel(1)
    • val = getChannel("foo")
  • params
Example:
id = addChannel("EGT", 1)
   temp = temp * 1000
Time Info
getUptime()
  • Returns
getDateTime()
    • Year
    • Month
    • Day
    • Hour
    • Minute
    • Second
    • Millisecond
