AnalogX
In the kit you will receive:
- AnalogX module
- 4 wire power and CAN pigtail
- 6 wire analog sensor input pigtail
- 1" shrink tube for installation
Compatible Sensors
See the CAN bus integration guide for information on mapping CAN data to telemetry channels.
AiM, MoTeC and other systems
Feature | Description |
Analog input voltage range | 0 - 5v |
DAC resolution | 12 bit SAR |
Sample output format | 0 - 5000mV |
Input impedance | Greater than 10 Meg Ohm |
Input voltage protection | 100v |
Pullup resistor | Optional on-board 2.2K pullup resistor for each channel (jumper enabled) |
Power input | 9 - 15volts, protected to 40v (intermittent) |
Weight | 6 grams |
Dimensions | 0.72" x 1.93" (18.3mm x 48.7mm) |
CAN baud rate | 500K and 1M, jumper configurable |
Address Space | 4 separate address spaces allows up to 4 AnalogX modules to operate on the same CAN network. (jumper configurable) |
Source Code
Power and CAN
Color | Assignment | Notes |
Red | 9-15v Power | Connect this to switched ignition power. 0.25A max consumption. |
Black | CAN High | |
Orange | CAN Low | |
Blue | Ground |
Sensor connections
Brown | Analog 1 input | 0-5v input |
Pink | Analog 2 input | 0-5v input |
Purple | Analog 3 input | 0-5v input |
Blue | Analog 4 input | 0-5v input |
Yellow | Voltage reference output | 5v @ 0.5A |
Black | Ground reference |
AnalogX CAN bus API
Adjusting Base ID
Closed | Closed | 0xE4600 (935424) |
Closed | Open | 0xE4700 (935680) |
Open | Closed | 0xE4800 (935936) |
Open | Open | 0xE4900 (936192) |
Address
Offset | What | Value |
0 | Channel Count | Total number of channels on device |
1 | Reserved | |
2 | Reserved | |
3 | Reserved | |
4 | Reserved | |
5 | Major Version | Firmware Major Version Number |
6 | Minor Version | Firmware Minor Version Number |
7 | Patch Version | Firmware Patch version number |
Configuration Group 1
Address
0 | Sample Rate | Rate to report sensor values ( 1 - 255Hz). Default sample rate is 50Hz. |
1 | Reserved | |
2 | Reserved | |
3 | Reserved | |
4 | Reserved | |
5 | Reserved | |
6 | Reserved | |
7 | Reserved |
Address
0 | Current Sample Rate | 1 - 255Hz |
1 | Reserved | |
2 | Reserved | |
3 | Reserved | |
4 | Reserved | |
Sample Broadcast
Scaling and Data format
- Scaling: 0-5000mV
- Data format: Little Endian
Address
- CAN ID: Base + 20
0 | Channel 1, low byte | |
1 | Channel 1, high byte | |
2 | Channel 2, low byte | |
3 | Channel 2, high byte | |
4 | Channel 3, low byte | |
5 | Channel 3, high byte | |
6 | Channel 4, low byte | |
7 | Channel 4, high byte |
