AnalogX
Revision as of 15:17, 27 March 2018 by Brentp (talk | contribs) (Wiring)
In the kit you will receive:
  • AnalogX module
Compatible Sensors
See the CAN bus integration guide for information on mapping CAN data to telemetry channels.
  • Note - RaceCapture's CAN mapping features currently only supports sensors with a linear (straight-line) response. Sensors with a curved response, such as thermistors, will not work with the built-in direct CAN mapping. We recommend using a temperature sensor with a linear response, such as the Texense Liquid Temperature Sensor or similar.
AiM, MoTeC and other systems
Feature Description
DAC resolution 12 bit SAR
Input voltage protection 100v
Power input 9 - 15volts, protected to 40v (intermittent)
Weight 6 grams
Source Code
Power and CAN
Color Assignment Notes
Red 9-15v Power Connect this to switched ignition power. 0.25A max consumption.
Black CAN High
Orange CAN Low
Blue Ground
Sensor connections
Brown Analog 1 input 0-5v input
Pink Analog 2 input 0-5v input
Purple Analog 3 input 0-5v input
Blue Analog 4 input 0-5v input
Yellow Voltage reference output 5v @ 0.5A
Black Ground reference
CAN termination
  • Note: Use a razor or very fine tipped screwdriver to break the bridge on the pad, scraping towards the outside of the circuit board. To re-enable the bridge, solder across the pads using a low wattage (15-30W) soldering iron to prevent damage to the pads.
AnalogX CAN bus API
Adjusting Base ID
Closed Open 0xE4700 (935680)
Open Closed 0xE4800 (935936)
Open Open 0xE4900 (936192)
Address
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
Configuration Group 1
Address
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
5 Reserved
6 Reserved
7 Reserved
Address
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
Sample Broadcast
Scaling and Data format
  • Scaling: 0-5000mV
  • Data format: Little Endian
Address
  • CAN ID: Base + 20
Offset What Value
0 Channel 1, low byte
1 Channel 1, high byte
2 Channel 2, low byte
3 Channel 2, high byte
4 Channel 3, low byte
5 Channel 3, high byte
6 Channel 4, low byte
7 Channel 4, high byte
