PodiumConnect
Revision as of 16:14, 15 February 2018 by Brentp (talk | contribs) (Android / iOS)
Getting Started
Installing the app
Install the app installer from the [downloads page http://podium.live/software]
Android / iOS
Running and Connection
  • Start the RaceCapture app.
Android / iOS
    • Note, the WiFi Access Point is open, with no password - you can set a password and encryption later.
First time setup wizard
Recommend setting up with windows/OSX to start.
  • Plug RaceCapture into the USB port on your computer and launch the app.
  • The app will present you with a startup wizard. Follow the steps.
Select the preset configuration matching the system you have
Select your favorite Tracks
  • Note: Only select the one track configuration per venue.
Create an account on Podium
Create an account on Podium http://podium.live - then follow the steps to create a Device. Note the Device ID provided, you will need to enter it into the wizard.
Select your cell provider
Select the cellular provider you will use.
Connecting your Data System
Testing Telemetry
Install your SIM card
Insert your SIM card by popping the drawer
  • Slide the SIM card tray back into the drawer, ensuring you engage the drawer slot carefully. Press until the drawer seats.
Testing Telemetry
  • Refresh this page when telemetry is broadcasting; you will see an "Ad Hoc event" listed.
