PodiumConnect
Getting Started
Installing the app
Android / iOS
Running and Connection
- Start the RaceCapture app.
Android / iOS
- Note, the WiFi Access Point is open, with no password - you can set a password and encryption later.
First time setup wizard
Select your favorite Tracks
- Select the tracks you will typically race at so PodiumConnect can detect the track location and calculate lap times. This is an important step to ensure you get valid data and lap times for your telemetry session.
Create an account on Podium / Setting Device ID
Select your cell provider
Freedom Pop
Further Setup
Connecting your Data System
Testing Telemetry
Install your SIM card
Verifying
Installing the unit
Install PodiumConnect in the passenger compartment, in an area that's protected from moisture and temperature extremes. Typically in an area that offers reasonable access to the unit to observe status LEDs,
Temporary alternative with reduced performance: You can also install the antenna to the windshield using a suction cup, or in the passenger compartment using zip ties, ensuring the antenna body of the antenna is 8" separated from metal structures.
