BMW E36 Guide
BMW E36 (1990 - 1999)
- Timer Mode: RPM
- Timer Speed: Medium
- Pulse Per Revolution: 3
TPS
- 0.62 volts at 0% throttle
- 4.64 volts at 100%
Engine Temperature
In research
Should be similar to E30
Fuel Level
Mapping in RCP
- 0.2v = 0 (empty)
- 1.33v = 25 (1/4)
- 2.2v = 50 (half)
- 2.95v = 75 (3/4)
- 3.53v = 100 (full)
You may want to average your fuel readings to compensate for slosh.
(Needs verification)
- 0 ohms empty
- ?? ohms 1/4
- ?? ohms 1/2
- ?? ohms 3/4
- 260 ohms full
Oil Pressure
You can get a few channels from the OBDII port of the E36 using the ASL Legacy OBDII Cable, but it is fairly slow to update. Useful channels are RPM, EngineTemp, and TPS. See the Enabling OBD-II Guide.
Assumes:
- Pin 10 on radio connector
setTickRate(10) --10Hz --virtual channels --addChannel("name",SR,prec,min,max,"unit") speeddiff_id = addChannel("Speed_",10,0,0,160,"MPH") gear_id = addChannel("Gear_",5,0,0,5,"gear") --global constants --edit these to match your car first = 4.20 second = 2.49 third = 1.66 fourth = 1.24 fifth = 1.00 final = 3.46 tirediameter = 24.7 --global variables rpm = 0 rpm_diff = 0 speed = 0 function updateSpeedDiff() rpm_diff = getTimerRpm(1) speed = rpm_diff*tirediameter*0.002975 speed = speed + 0.5 -- round because 0 prec. truncates setChannel(speeddiff_id, speed) end function updateGear() rpm = getTimerRpm(0) local gearErr = 0.15 local gear = 0 if speed > 2 then ratio = rpm/(rpm_diff*final) if ((first - ratio)^2) < (gearErr^2) then gear = 1 end if ((second - ratio)^2) < (gearErr^2) then gear = 2 end if ((third - ratio)^2) < (gearErr^2) then gear = 3 end if ((fourth - ratio)^2) < (gearErr^2) then gear = 4 end if ((fifth - ratio)^2) < (gearErr^2) then gear = 5 end end setChannel(gear_id, gear) end function onTick() updateSpeedDiff() updateGear() end
