RaceCapturePro Lua Scripting
Revision as of 15:56, 24 November 2018 by Brentp (talk | contribs) (Troubleshooting)
Example Scripts and How-Tos
Lua Script Basics
Writing your script
onTick() function
Viewing the output log
Controlling the onTick() rate
count = 0
  count = count + 1
  println("Tick: " ..count)
Given:
  temperature = getAnalog(0)
  if temperature > 212 then
    setGpio(0, 1)
  else
    setGpio(0, 0)
Combining multiple functions
Example:
function checkTemps()
function checkAutoLogging()
  checkTemps()
  checkAutoLogging()
Debugging your script
Example:
    println("over temp!")
    setGpio(0, 1)
  else
    println("under temp")
    setGpio(0, 0)
Out of memory issues
If you are seeing out of memory issues, try the following:===Mark variables in your script as local===Lua makes variables global by default, which is typically opposite of other programming languages. Since global variables consume more memory, try making variables declared in your function local:
function addSomeNumbers()
  local var1 = 3
  local  var2 = 5
  return var1 + var2
Simplify your script
 collectgarbage()
-- other code --
Try a Lua minimizer
Lua Reference
More examples
API Reference
getGpio( channel )
  • params
    • channel: integer 0 - 2
  • returns:
setGpio ( channel, state )
  • params
  • returns:
    • none
getButton()
  • params
    • none
  • returns
PWM / Analog Output functions
  • params
  • returns
    • none
setPwmClockFreq( frequency )
  • params
  • returns
    • none
  • params
    • returns
  • none
Timer / RPM Sensor Functions
getTimerRpm(channel)
  • params
    • returns: RPM value
getTimerPeriodMs(channel)
  • params
    • returns: millisecond value
getTimerFreq(channel)
  • params
    • returns: Frequency in Hz
getTimerRaw(channel)
  • params
Analog Sensor Functions
getAnalog(channel)
  • params
getImu(channel)
  • params
  • returns
getImuRaw(channel)
  • params
  • returns
    • The raw accelerometer value
GPS Sensor Functions
getGpsPos()
  • params
    • none
  • returns
getGpsSpeed()
  • params
    • (none)
  • returns
    • The current speed in MPH
getGpsQuality()
  • params
    • (none)
  • returns
getGpsSats()
  • params
    • (none)
  • returns
getGpsTime()
  • params
    • (none)
  • returns
    • The current GPS time value
getGpsDist()
  • params
    • (none)
  • returns
    • The distance, in Miles
getGpsAltitude()
  • Added: v2.9.0
  • Parameters: None
  • Returns: <altitude>
getLapCount()
  • params
    • (none)
  • returns
getLapTime()
  • params
    • (none)
  • returns
getPredTime()
as of 2.12.0 firmware
  • params
    • (none)
  • returns
getGpsSec()
  • params
    • (none)
  • returns
getAtStartFinish()
  • params
    • (none)
  • returns
getTimeDiff(time1, time2)
  • params
    • time1
    • time2
  • returns
getTimeSince(time)
  • params
    • time
  • returns
CAN Bus functions
initCAN(channel, baud )
  • params
  • returns
  • params
  • returns
Example:
channel = 0
id = 1234
ext = 0
data = {11,22,33}
rxCAN(channel, [timeout] )
  • params
  • returns
Example:
  • params
  • returns
readOBD2( PID )
  • params
  • returns
Logger Control Functions
onTick()
  • params:
    • (none)
  • returns:
    • (none)
Example:
setTickRate(rate)
  • params
  • returns
    • (none)
SD Logging control
isLogging()
  • params
    • (none)
  • returns
startLogging()
  • params
    • (none)
  • returns
    • (none)
stopLogging()
  • params
    • (none)
  • returns
    • (none)
setLed( led, state )
  • params
    • led (1-3)
  • returns
    • (none)
setBgStream( on/off )
  • params
  • returns
    • (none)
getBgStream()
  • params
    • (none)
  • returns
Serial Port Communications
Port mappings
0 = USB port
1 = GPS port
2 = Internal telemetry port (MK2/3/Apex only)
3 = Bluetooth port
4 = Auxiliary / WiFi port
5 = WiFi port 6 = External Auxiliary port (RaceCapture/Pro MK3 and RaceCapture/Apex only)
  • Note: We only recommend using ports 3 and 4 for connecting script to external devices. Ports 0 - 2 have been included for reference; using them may interfere with normal operations of the unit.
  • params
  • returns
readCSer( port, [timeout])
  • params
  • returns
readSer( port, [timeout])
  • params
    • port: Serial port 0 - 4
writeCSer( port, data )
  • params:
  • returns:
(no return values)
writeSer( port, data )
  • params
  • returns:
(no return values)
flashLoggerCfg()
  • params
    • (none)
  • returns
    • (none)
setPwmClockFreq( freq )
  • params
  • returns
    • (none)
getPwmClockFreq()
  • params
    • (none)
  • returns
calibrateImuZero()
  • params
    • (none)
  • returns
    • (none)
Virtual Channels
  • params
  • returns
  • Parameters
  • Returns
    • (number) The current value of the channel if available, or nil if the value is not available. You should always check if the value is present before using it for other purposes.
  • Examples:
val = getChannel(1)
--get the channel by name
rpm = getChannel("RPM")
if rpm ~= nil then
  • params
Example:
id = addChannel("EGT", 1)
   temp = temp * 1000
Time Info
getUptime()
  • Returns
getDateTime()
    • Year
    • Month
    • Day
    • Hour
    • Minute
    • Second
    • Millisecond
