RaceCapturePro Sensors
GM-Style | |||||||||||||||||
AEM | |||||||||||||||||
3 bar MAP sensor |
| Freescale MXP4250AP | 2.5 bar MAP sensor
| Schrader |
RPM | |||||||||||||||||
| Autosport Labs CoilX |
The CoilX sensor module is designed to safely interface the noisy, high voltage RPM signal at the ignition coil pack primary into a clean signal that RaceCapture/Pro can process. | |||||||||||||||
| Mfg / Part # | Image | Notes | Pulse Channel Configuration | ||||||||||||||
| Hamlin 55505 |
| Cherry GS100701 |
| Sharp GP2D12 |
Steps to calibrate:
| Texense RHS |
| KA Sensors RHL3 |
| Various Mfg / String Potentiometer |
Air / Fuel Ratio Sensors | |||||||||||||||||
| Texense LSU 4.9 Sensor | Built-in wiring | Screws into O2 sensor port |
LSU 4.9 sensor |
Wiring Analog Sensors
- Input Impedance: 15K ohm
Temperature Sensor
Pullup resistor
Sensor Ground
Active Sensors
- Power
- Ground
- Signal Output
Wiring the Speed Sensor
- Power: Connect the sensor's power to the 5v Vref on RaceCapture/Pro
- Ground: Connect the sensor's ground connection to the ground shared by RaceCapture/Pro
- Sensor Output: Connect the Sensor Output to one of RaceCapture/Pro's timer input channels
Optional pull up resistor
- Throttle Position Sensors
- Linear sensors
- String Potentiometers
- Fuel Level Sensors
Standard Variable Resistor (Potentiometer)
These are typically found in Throttle Position Sensors (TPS), string potentiometers, and linear sensors.
Fuel Level Sensors
Also a variable resistor, these provide a variable resistance based on the level of the float.
If you already have a gauge connected
You will not need a pullup resistor - the gauge's internal circuitry already provides one. You will only need to tap into the existing signal feeding the fuel gauge sender. Jump to the calibration process below.
- Note you will need to ensure the sender does not exceed 5v during calibration. if it does, you will need an additional voltage divider to scale the voltage down to 0-5v required by the RaceCapture input.
If you have no gauge / you want to only use RaceCapture for your dashboard gauge
If you only have the sender and want to directly integrate with RaceCapture's analog input, follow this procedure.
- Choose a pull-up resistor value based on the the sender's ohm range. If it is less than 1000 ohms, then choose a 1000 (1K) ohm resistor as your pull-up. If the sender range is higher than 1000 ohms, choose a 2.2K resistor.
- Rule of thumb - choose a resistor that is about 2X to 4X the maximum resistance of the sender.
- A 1/2 watt, 1% accuracy resistor is recommended.
Calibration
- Empty (0%)
- 1/4 (25%)
- 1/2 (50%)
- 3/4 (75%)
- Full (100%)
Set up the Analog Channel
- Choose an available analog input for your Fuel Level channel, then select the basic fuel level preset by selecting FuelLevel in the dropdown list.
- This pre-sets the units (%), logging precision and min / max values. You can edit this by pressing the gear button next to the channel name.
- Set the sample rate to 1Hz.
Sensor Breakout Board
