Add TPMS Data
Revision as of 17:37, 16 April 2019 by Sbarton (talk | contribs) (→Notes)
You can cheaply and easily add Tire Pressure Monitor System data to your Race Capture Pro, Race Capture Track or Podium Connect devices with the $225 TrailBrake.com CAN enabled TPMS.
The system is available in external screw on sensors and internal rim mounted sensors. Both are available for $225. Both have channels for pressure, temperature, volts (to monitor battery life), and leak alarm.
Race Capture Pro MK3
For the Race Capture Pro MK3, you can wire CAN High and CAN Low to either CAN 1 or CAN 2 on the Molex connector. CAN 1 is recommended as that is what the provided Preset defaults to. If you wire it to CAN bus 2, you will have to go into each TPMS channel and change it from CAN Bus 1 to CAN Bus 2.
Podium Connect
For Podium Connect, you can add wires to CAN2 on the Molex connector. Again, after applying the Preset, you will have to go in and change the CAN Bus 1 to CAN Bus 2 for each TPMS channel.
Race Capture Pro MK2 and Race Capture Track MK2
You can also create a custom RJ45 cable and put the TPMS on either CAN 1 or CAN2. Please see this link for more detailed info. This would also allow the TPMS system to work Race Capture Track and older Race Capture Pro MK2 systems.
RJ45 Splitter
Configuring Settings in Race Capture App
Enable CAN
Now that you have the system wired up, go into the Race Capture App, turn on CAN Bus and make sure the baud rate is set to 1M for the CAN Channel you wired the TPMS to.
Install Preset Channels
Now go to CAN Mapping, click on Presets. Click Update at bottom, then Select Tyre TPMS.
If you wired the TPMS to CAN Bus 2, you will need to edit each channel and change the CAN Bus from CAN Bus 1 to CAN Bus 2.
Write config and verify
Notes
Note: The external batteries should be replaced when they fall below 2.0 volts. You can set alarms/alerts in Race Capture App to notify you when the voltage starts to get too low.
Note: The pressure resolution is about 0.75PSI, therefore you rprobably only need to see a resolution of 0 (ie, no decimal places).
Note: The temperature on my system seemed to read about 4* high and was not consistent from wheel to wheel. Everything else seemed pretty accurate.
