CAN Crossover Cable
Most of Autosport Labs CAN device cables are wired to CAN Bus Channel 1. This can be a problem if you want to integrate 2 or more CAN systems that run at a different baud rate, or if they interfere with each other. For example AIM CAN bus baud rate is 1M and OBDII baud rate is 500k. You can add these 2 devices to a Race Capture device with an RJ45 Splitter. Problem is the stock ASL AIM to RCP cable is wired to CAN 1 and the ASL OBDII cable is also wired to CAN 1. These two devices cannot be on the same CAN channel because they use different baud rates. You can easily build an RJ45 CAN Crossover cable to swap the CAN 1 and CAN 2 channel wiring for that device. You can either permanently modify one of the device's RJ45 cable, or create a CAN Crossover cable adapter.
You will need:
- RJ45 Crimping tool
- CAT5E (or CAT6) terminal ends
- CAT5E extension cable (if making a crossover cable adapter)
- Pin1: Orange/White
- Pin2: Orange
- Pin3: Green/White
- Pin4: Blue
- Pin5: Blue/White
- Pin6: Green
- Pin7: Brown/White
- Pin8: Brown
ASL Cables are wired the following:
- Pin1 (Orange/White): GND
- Pin2 (Orange): CAN1 High
- Pin3 (Green/White): CAN1 Low
- Pin4 (Blue): CAN2 High
- Pin5 (Blue/White): CAN2 Low
- Pin6 (Green): N/C
- Pin7: (Brown/White): N/C
- Pin8: (Brown): 12v
- Pin2 (Blue): CAN2 High
- Pin3 (Blue/White): CAN2 Low
- Pin4 (Orange): CAN1 High
- Pin5 (Green/White): CAN1 Low
- Pin6 (Green): N/C
You can cut off the RJ45 end on the stock ASL cable and modify it. Or you can buy an ethernet extension cable and cut the male end off that and modify it to make an adapter that the stock ASL cable will plug into.
