MJLJ V4 Operation Guide
Revision as of 17:46, 2 June 2008 by Brentp (talk | contribs) (→Editing the Ignition Map: added visualization instructions)
First time use
Setting the Serial Port
Configuring MAP or TPS
Connecting to the MJLJ
Common connection problems
Timeout reading runtime data
Could not open port
Either:
At a glance: Main Screen
Runtime Gauges
Ignition Advance
Load
Auxiliary Input
The Auxiliary Input can be customized to your preference, under "Tools/Advance Correction Options"
  • Auxiliary Input Label: Change this to match your particular use. Example: "Coolant Temp"
Advance Correction
Displays the current Ignition Advance correction value. This correction value represents the value calculated from the Advance Correction table, and ranges from -59 to 59 degrees. This correction value is applied to the value derived from the main Ignition Advance table.
Ignition Map
Editing Ignition Map
Adjusting ignition advance
  • Changing single value
  • Changing multiple cells
Adjusting Load / RPM Bins
  • Ctrl-B in the main window
Controller Options
User Configurable Outputs
Output Type
Output Mode
Activation Point
Hysteresis on outputs
Shift Light
Rev Limit
Commit to Flash
Additional Options
Load Axis Calibration
Guided TPS calibration
Advanced Uses
Load / Save calibration
Edit Values
Enable hardware switch
Important Usage Notes
Charting / Runtime view
Tuning Perspective
Hot Keys
Visualization
Data logging
Quick Data Logging
Mark Datalog
Stop Logging
Logfile Format
  • RPM: Engine RPM
Advanced Topics
