MJLJ V4 Operation Guide
Revision as of 20:19, 2 June 2008 by Brentp (talk | contribs) (→‎Auxiliary Input Channel Configuration: content for aux input channel customization)
First time use
Setting the Serial Port
Configuring MAP or TPS
Connecting to the MJLJ
Common connection problems
Timeout reading runtime data
Could not open port
Either:
At a glance: Main Screen
Runtime Gauges
Ignition Advance
Load
Auxiliary Input
Advance Correction
Displays the current Ignition Advance correction value. This correction value represents the value calculated from the Advance Correction table, and ranges from -59 to 59 degrees. This correction value is applied to the value derived from the main Ignition Advance table.
Configuring Engine Parameters
Number of Cylinders
Cranking Advance
Specify the Ignition advance used during cranking. The controller will use this value when the engine RPM drops below approximately 500 RPMs.
Trigger Offset
Use this value to adjust for minor crank sensor misalignments, up to +/-5 degrees. Note, any value other than zero will limit the ignition map adjustability at the extents.
EDIS PIP Filter Level
To read the controller's current configuration, click the toolbar icon Mjlj read config toolbar.jpg. The current ignition configuration will be read from the MJLJ and displayed in the grid.
Ignition Map
Editing Ignition Map
Adjusting ignition advance
  • Changing single value
  • Changing multiple cells
Adjusting Load / RPM Bins
  • Ctrl-B in the main window
The Edit Ignition Bin values dialog will appear. Here, you can edit the bin values for the Load and RPM axis. Mjlj operation guide edit bin values.png
Advance Correction
  • Bins: The Bins determine which Advance Correction value is selected based on the value measured from the Auxiliary Input channel. You can specify a spread of values that suits your preferences, creating coarse or fine regions between bins.
  • Correction: The Ignition Advance Correction for the matching Bin. This value can be +/- 59 degrees.
Operation
User Output Configuration
User Configurable Outputs
Output Type
Output Mode
Activation Point
Hysteresis on outputs
Shift Light
Rev Limit
After editing the ignition map or controller options, you may write the changes to the controller. To do this, click the Write Ignition Configuration toolbar icon Mjlj write config toolbar.png to send your changes to the controller.
Commit to Flash
To make the changes permanent in the Controller's Flash memory, Click the 'Commit configuration to Flash' toolbar icon Mjlj flash config toolbar.png. The controller will write the configuration to flash memory, and changes will be preserved across controller power-cycles.
Additional Options
Load Axis Calibration
Guided TPS calibration
Advanced Uses
Load / Save calibration
Edit Values
Gauge / Label Customization
  • Auxiliary Input Label: Specify a label to match your particular use. Example: "Coolant Temp"
Enable hardware switch
Important Usage Notes
Charting / Runtime view
Tuning Perspective
Editing the Ignition Map
Hot Keys
Visualization
Data logging
Quick Data Logging
Mark Datalog
Stop Logging
Open Datalog
Logfile Format
  • RPM: Engine RPM
