MJLJ V4 Operation Guide
First time use
Setting the Serial Port
Configuring MAP or TPS
Connecting to the MJLJ
Common connection problems
Timeout reading runtime data
- Does the MJLJ have power, and connected to the computer with a standard serial cable or compatible USB-Serial adapter?
Could not open port
Either:
At a glance: Main Screen
Runtime Gauges
Ignition Advance
Load
The Load gauge shows either KPa or TPS %, depending on your Controller's configuration and Configuration software setting. For MAP sensor based units the scale can be further adjusted to show 0-103 KPa for normally aspirated engines. With forced induction applications the gauge can be set to show the full 0-255KPa range supported by the on-board MAP sensor.
Auxiliary Input
- Advance Correction: The Ignition Advance Correction value is selected from the Advance Correction Table based on the value measured on the Auxiliary Input port.
- User Defined Outputs: The Auxiliary Input value can be used to trigger one or more User Defined Outputs.
Advance Correction
Configuring Engine Parameters
Number of Cylinders
Cranking Advance
Specify the Ignition advance used during cranking. The controller will use this value when the engine RPM drops below approximately 500 RPMs.
Trigger Offset
Use this value to adjust for minor crank sensor misalignments, up to +/-5 degrees. Note, any value other than zero will limit the ignition map adjustability at the extents.
EDIS PIP Filter Level
. The current ignition configuration will be read from the MJLJ and displayed in the grid.
Ignition Map
Editing Ignition Map
Adjusting ignition advance
- Changing single value
- Changing multiple cells
- Ignition Advance range: Allowable ignition advance range is 0 to 59 degrees BTDC.
Adjusting Load / RPM Bins
- Ctrl-B in the main window
Advance Correction
- Bins: The Bins determine which Advance Correction value is selected based on the value measured from the Auxiliary Input channel. You can specify a spread of values that suits your preferences, creating coarse or fine regions between bins.
- Correction: The Ignition Advance Correction for the matching Bin. This value can be +/- 59 degrees.
- Peak Hold: Hold the advance correction for X ignition events after a peak value is detected on the Auxiliary Input channel. After the Peak Hold decays, the Advance correction drops down to the correction value for the current Auxiliary Input value. A value of zero disables this feature.
Operation
User Output Configuration
User Configurable Outputs
Output Type
- Auxiliary: Select this type to activate on an Auxiliary Input value threshold.
Output Mode
Activation Point
Hysteresis on outputs
- Auxiliary configured outputs: Hysteresis is set at 1 configured Unit.
Shift Light
Rev Limit
After editing the ignition map or controller options, you may write the changes to the controller. To do this, click the Write Ignition Configuration toolbar icon
to send your changes to the controller.
Important Note: Writing the ignition configuration only updates the Controller's RAM. If changes are not persisted to the controller's Flash memory, the changes will be lost if the controller loses power (e.g. ignition key turned to 'off'). This behavior is by design. Persisting the data to flash requires a significant amount of time and momentarily pauses the controller's operation while the Flash memory is written.
Commit to Flash
To make the changes permanent in the Controller's Flash memory, Click the 'Commit configuration to Flash' toolbar icon
. The controller will write the configuration to flash memory, and changes will be preserved across controller power-cycles.
Additional Options
Load Axis Calibration
Guided TPS calibration
Advanced Uses
Load / Save calibration
Edit Values
Gauge / Label Customization
- Auxiliary Input Label: Specify a label to match your particular use. Example: "Coolant Temp"
- Auxiliary Input Units: This represents the unit of measurement: Exampe: "Degrees F."
- Scaling Factor: The default scaling factor of 1 gives a input range of 0-255. Adjust the scaling factor to increase the visual range to match your needs.
- Gauge Major Tick Interval / Gauge Minor Tick Interval: These settings adjust the visual appearance of the analog gauge used to display the Auxiliary Input value.
Edit calibration values
Enable hardware switch
- No Action: The software only alerts you of the change.
- Prompt to read configuration: The software prompts you to read the Ignition Configuration the controller was just switched to.
- Auto-Read configuration: The software automatically reads the Ignition Configuration the controller was just switched to, discarding any in-progress changes made in the software.
Important Usage Notes
Charting / Runtime view
Tuning Perspective
- Red Ball: The red ball indicates the closest run-time cell the controller is using for the ignition advance; this will move around as the engine RPM and load changes.
- Yellow Ball: The yellow ball indicates your current editing point.
Editing the Ignition Map
- Navigation: Use the arrow keys to move the editing point around the Ignition Map.
- Increase/Decrease advance: To increase advance at the editing point, hold down the ctrl-key and press the up arrow key. Conversely, to decrease the ignition advance, hold down the ctrl-key and press the down arrow.
- Modify Load/RPM bins: You can increase/decrease the selected RPM bin by pressing Alt-left arrow / Alt-right arrow. Correspondingly, the selected Load bin can be modified by pressing Alt-up arrow / Alt-down arrow.
Hot Keys
- Lock editing with runtime: Pressing 'L' on the keyboard toggles locking the editing point (yellow ball) with the runtime point(red ball), making it easier to edit the map in the region where the engine is running.
- Enable real-time config update: Pressing 'U' on the keyboard toggles real-time updating of the edited ignition point. The values are stored in the Controller's RAM, but not persisted to flash.
Visualization
- Rotate: Click and drag the map to rotate the Ignition Map in 3D
- Pan: Hold Shift + click and drag to Pan the Ignition map
- Zoom: Hold Alt + click and drag to zoom the Ignition map
Data logging
Quick Data Logging
Mark Datalog
Stop Logging
Open Datalog
- Zoom Use this to zoom in and out of your Datalog file.
- Navigation The forward/reverse buttons adjusts the view 10 seconds forward or backwards in time. The Fast forward/reverse buttons adjust the view 60 seconds.
Logfile Format
- Timestamp: The time of the log file entry
- RPM: Engine RPM
- Load: Engine Load, in KPa or TPS %
- Advance: Actual Ignition Advance in degrees BTDC
- RPM_Accel: RPM Acceleration, in RPM/sec
- Load_Accel: Load Acceleration, in KPa/sec or TPS/sec
- Aux Input: Auxiliary Input value. This header value will change based on the configured label under "Advance Correction" preferences.
- Advance_Correction Advance Correction value calculated from the Advance Correction table.
- Mark_interval: Indicates a marked portion of the log data. 1 = Marked.
