Harness specifications
Standardized Connections
Available cabling
CAN extension cables
| Orderable SKU | Description |
| ASL_M8_CAN_PATCH_1M | 1 meter CAN extension cable |
| ASL_M8_CAN_PATCH_2M | 2 meter CAN extension cable |
| ASL_M8_CAN_PATCH_3M | 3 meter CAN extension cable |
| ASL_M8_CAN_PATCH_4M | 4 meter CAN extension cable |
CAN splitter
| ASL_CAN_SPLITTER | Single channel CAN splitter |
M8 CAN + power pigtail
Used as a primary power + single CAN bus connection to enable a one cable power + data solution.
| ASL_POWER_CAN_PIGTAIL_2M | Power + CAN pigtail, 2 meter |
Dual CAN interconnect (RJ45)
| ASL_DUAL_CAN_M8_1M | Dual CAN M8 6P male to M8 6P male, 1 meter |
| ASL_DUAL_CAN_RJ45_M8_1M | Dual CAN RJ45 to M8 6P male, 1 meter |
Inline CAN terminator
| ASL_CAN_TERMINATOR | Inline CAN terminator, M8 4P |
Analog/Digital cabling
Sensor Pigtail
| ASL_M8_SENSOR_PIGTAIL_2M | M8 3P to bare wire sensor pigtail, 2M, 24 AWG |
Sensor Extension Cable
| ASL_M8_SENSOR_EXTENSION_1M | M8 3P sensor extension cable, 1 meter |
| ASL_M8_SENSOR_EXTENSION_2M | M8 3P sensor extension cable, 2 meter |
| ASL_M8_SENSOR_EXTENSION_3M | M8 3P sensor extension cable, 3 meter |
| ASL_M8_SENSOR_EXTENSION_4M | M8 3P sensor extension cable, 4 meter |
| ASL_4X_SENSOR_SPLITTER | 4X analog / digital sensor splitter |
| ASL_DELPHI3_M8 | Delphi GT150 3 pin to M8, 2 meters |
| ASL_LINEAR_TEMP_M8 | Autosport Labs linear temperature to M8, 2 meters |
Connector Standard
Power/ CAN Single interconnect
- Connector: M8 4P
| Pin | Connection | Notes |
| 1 | CAN low | |
| 2 | Power | Red, 12v / 1A (12W) |
| 3 | CAN high | |
| 4 | Ground | Black |
- Connector: M8 6P
| 1 | CAN1 low | |
| 2 | CAN2 low | |
| 3 | CAN2 high | |
| 4 | Ground | |
| 5 | CAN1 high | |
| 6 | 12v |
Single analog/digital channel
Quad analog/digital channels
- Connector: M8 8P
| 1 | Analog/Digital 1 | |
| 2 | Analog/Digital 2 | |
| 3 | Analog/Digital 4 | |
| 4 | Vref | 5v @ 1A, combined with pin 6 |
| 5 | Ground | |
| 6 | Vref | 5v @ 1A, combined with pin 4 |
| 7 | Analog/Digital 3 | |
| 8 | Ground |
