TireX
High Performance
Rugged and Compact
Flexible Setup
Feature | Description |
Sensor type | Thermal array |
Object temperature range | 0 - 127.5C (tire temperature mode) / 0 - 255C (full frame mode) |
Accuracy | 1C |
Temperature zones (tire) | 1 / 2 / 4 / 8 / 16 |
Sample rate | 0.5 - 64Hz (Tire temperature mode) 0.5 - 10Hz (Full frame mode) |
Processing Engine | 32 bit |
Configurable positions | 4 (Left-Front, Right-Front, Left-Rear, Right-Rear); Reversible orientation |
Electrical | |
Interface | CAN 2.0 |
Supply voltage | 6 - 12v |
Power | 200mW |
CAN bus | |
CAN baud rate | 500K and 1M, jumper configurable (500K default) |
Physical / Environmental | |
Construction | CNC aluminum |
Weight | 10 grams |
IP rating | IP65 |
Dimensions / Mounting
Mounting Distance
- 205 width = 71mm
- 225 width = 79mm
- 235 width = 82mm
- 245 width = 85mm
- 255 width = 89mm
- 275 width = 96mm
- 315 width = 110mm
- If only using 4 channels, you can mout 4x the distance
Electrical / CAN connection
Connection is provided by a standard industrial M8 4P male plug. Pigtails and connectors are available from Autosport Labs, or 3rd parties.
Pin | Connecton |
Pin 1 | CAN Low |
Pin 2 | Voltage supply (6-12v) |
Pin 3 | CAN High |
Pin 4 | Ground |
Zone Configuration
Zones | Coverage |
CAN bus protocol
Formula
- Example:
- Formula: A / 100
- Real-world value: 0.95
Data encoding
Endian
Single and mulit-byte values
Value | Symbol Reference |
8 Bit values | A |
Default Main Base ID
Adjusting Main Base ID
Sensor Position Offset
0 | Left-Front | 0x0 (0) |
2 | Left-Rear | 0x200 (512) |
Left-Front | 0xA100 |
Right-Front | 0xA200 |
Left-Rear | 0xA300 |
Right-Rear | 0xA400 |
CAN ID: Sensor Base ID + 0
1 | Temperature Zones | unsigned | A * 1 | Number of configured temperature zones (1 / 2 / 4 / 8 / 16) |
3 | Reserved | |||
4 | Reserved | |||
CAN ID: Sensor Base ID + 2
1 | Reserved | |||
2 | Reserved | |||
3 | Reserved | |||
4 | Reserved | |||
Configuration Preferences
CAN ID: Sensor Base ID + 3
2 | Sensor Position | unsigned | A * 1 | Location of the sensor on the vehicle. This position adjusts the Sensor Base ID. Valid Positions 0 (Left-Front) / 1 (Right-Front) / 2 (Left-Rear) / 3 (Right-Rear). Specifying an invalid value will select the default value of 0 (Left-Front). Note: The sensor position affects the orientation of the sensor zones. Sensor Position 1 and 3 will report temperature zones left - right; Position 0 and 2 will report temperature zones right - left. |
4 | Reserved | |||
5 | Reserved | |||
6 | Reserved | |||
7 | Reserved |
Calibration Preferences
CAN ID: Sensor Base ID + 4
1 | Ambient temperature compensation | unsigned | A * 1 | Value in C |
2 | Sensor Resolution | unsigned | 16-19 | Sensor ADC resolution, in bits |
3 | Reserved | |||
4 | Reserved | |||
5 | Reserved | |||
6 | Reserved | |||
7 | Reserved |
1 Zone
2 Zones
4 Zones
8 Zones
16 Zones
Full Frame Mode
