Dual CAN Hub
Revision as of 06:08, 7 March 2021 by Brentp (talk | contribs)
The Dual CAN hub expands two CAN bus networks into twin 4 expansion ports.
Power is provided through a single CAN + power interconnect, which powers the connected data system (e.g. RaceCapture) in addition to devices connected the CAN hub ports.
Pinout
Connecting RaceCapture
To connect RaceCapture to the Dual CAN hub, use the RaceCapture Integration cable, available separately
  • Supports two CAN bus networks
  • Input power + CAN connection for CAN1, suited for single-cable OBDII or ECU connection
  • contains 4 M8 CAN ports per network (8 ports total)
  • Includes 2 meter power + CAN pigtail
  • RaceCapture Integration cable available separately
  • Dimensions: 125x75x43mm
  • Weight: 200 grams
