RaceCapturePro Lua Scripting
Example Scripts and How-Tos
Lua Script Basics
Writing your script
onTick() function
function onTick() println("hello from RaceCapture/Pro") end
Viewing the output log
Controlling the onTick() rate
count = 0 setTickRate(10) function onTick() count = count + 1 println("Tick: " ..count) end
Given:
function onTick() temperature = getAnalog(0) if temperature > 212 then setGpio(0, 1) else setGpio(0, 0) end end
Combining multiple functions
Example:
Debugging your script
Example:
function onTick() temperature = getAnalog(0) println("current temp: " ..temperature) if temperature > 212 then println("over temp!") setGpio(0, 1) else println("under temp") setGpio(0, 0) end end
Out of memory issues
Simplify your script
Try a Lua minimizer
Lua Reference
More examples
API Reference
getGpio( channel )
- params
- channel: integer 0 - 2
- returns:
setGpio ( channel, state )
- params
- returns:
- none
getButton()
- params
- none
- returns
PWM / Analog Output functions
- params
- returns
- none
setPwmClockFreq( frequency )
- params
- returns
- none
- params
- returns
- none
Timer / RPM Sensor Functions
getTimerRpm(channel)
- params
- returns: RPM value
getTimerPeriodMs(channel)
- params
- returns: millisecond value
getTimerFreq(channel)
- params
- returns: Frequency in Hz
getTimerRaw(channel)
- params
Analog Sensor Functions
getAnalog(channel)
- params
getImu(channel)
- params
- returns
getImuRaw(channel)
- params
- returns
- The raw accelerometer value
GPS Sensor Functions
getGpsPos()
- params
- none
- returns
getGpsSpeed()
- params
- (none)
- returns
- The current speed in MPH
getGpsQuality()
- params
- (none)
- returns
getGpsSats()
- params
- (none)
- returns
getGpsTime()
- params
- (none)
- returns
- The current GPS time value
getGpsDist()
- params
- (none)
- returns
- The distance, in Miles
getGpsAltitude()
- Added: v2.9.0
- Parameters: None
- Returns: <altitude>
getGpsSec()
- params
- (none)
- returns
Lap Statistics
getLapCount()
- params
- (none)
- returns
getLapTime()
- params
- (none)
- returns
getPredTime()
as of 2.12.0 firmware
- params
- (none)
- returns
getAtStartFinish()
- params
- (none)
- returns
resetLapStats()
since 2.16.0
- params
- (none)
- returns
- (none)
Time Functions
getTickCount()
- params
None
- returns
CAN Bus functions
initCAN(channel, baud )
- params
- returns
- params
- returns
Example:
rxCAN(channel, [timeout] )
- params
- returns
Example:
- params
- returns
readOBD2( PID )
- params
- returns
Logger Control Functions
onTick()
- params:
- (none)
- returns:
- (none)
Example:
setTickRate(rate)
- params
- returns
- (none)
SD Logging control
isLogging()
- params
- (none)
- returns
startLogging()
- params
- (none)
- returns
- (none)
stopLogging()
- params
- (none)
- returns
- (none)
setLed( led, state )
- params
- led (1-3)
- returns
- (none)
setBgStream( on/off )
- params
- returns
- (none)
getBgStream()
- params
- (none)
- returns
Serial Port Communications
Port mappings
- 0 = USB port
- 1 = GPS port
- 3 = Bluetooth port
- 4 = Auxiliary / WiFi port
- params
- returns
readCSer( port, [timeout])
- params
- returns
readSer( port, [timeout])
- params
- port: Serial port 0 - 4
writeCSer( port, data )
- params:
- returns:
(no return values)
writeSer( port, data )
- params
- returns:
(no return values)
flashLoggerCfg()
- params
- (none)
- returns
- (none)
setPwmClockFreq( freq )
- params
- returns
- (none)
getPwmClockFreq()
- params
- (none)
- returns
calibrateImuZero()
- params
- (none)
- returns
- (none)
Virtual Channels
- params
- returns
- Parameters
- Returns
- Examples:
--get the channel by name rpm = getChannel("RPM") if rpm ~= nil then println("rpm channel: " ..rpm) end
- params
Example:
id = addChannel("EGT", 1) function onTick() temp = getAnalog(0) --read analog channel 0 temp = temp * 1000 setChannel(id, temp) --sets the virtual channel value end
Time Info
getUptime()
- Returns
getDateTime()
- Year
- Month
- Day
- Hour
- Minute
- Second
- Millisecond
Dashboard Control
txButton()
Simulates button press events for dashboard navigation and control. RaceCapture dashboard must be connected for function to have effect.
- params
- button_id: ID of button to transmit. 0 = left button;1 = right button
- returns
- (nothing)
ShiftX2/3 control
sxSetConfig()
sxSetConfig()
- params
- returns
sxCfgLinearGraph()
- params
- returns
sxSetLinearThresh()
- params
- Red: Red LED value (0-255)
- Flash: 0-10Hz (0 = sold on)
- returns
sxUpdateLinearGraph()
- params
- returns
- (none)
sxSetAlert()
- params
- returns
sxSetAlertThresh()
- params
- returns
sxUpdateAlert()
- params
- returns
sxSetDisplay()
- params
- Digit index (must be 0)
- returns
sxSetLed()
- params
- returns
sxRxButton()
- params
- (none)
- returns
- button_id (ID of button. left button = 0, right button = 1)
local id, state = sxRxButton() if id ~= nil then println('button ' ..id ..' state ' ..state) end
Helper Functions
calcGear()
- params
- returns
local gear = calcGear(62.7, 3.45, 4.23, 2.52, 1.66, 1.22, 1.0, 0.8) if gear ~= nil then println('gear: ' ..gear) end
- params
- Speed Channel name
- RPM Channel name
- returns
local gear = calcGear('Speed', 'RPM', 62.7, 3.45, 4.23, 2.52, 1.66, 1.22, 1.0, 0.8) if gear ~= nil then println('gear: ' ..gear) end
