ShiftX3
  • ShiftX3
Dimensions
Compatibility
ShiftX3 is compatible with:
  • RaceCapture/Track MK2,MK3
  • RaceCapture/Pro MK2,MK3,MK4
  • RaceCapture/Apex
  • PodiumConnect MK1,MK2
Firmware Requirements
Connection and Installation
Mounting ShiftX3
  • RJ45 Splitter
  • RJ45 network cable
  • Plug the OBDII cable into the CAN hub
Non OBDII installation or Direct wire (PodiumConnect, RaceCapture/Apex)
If your system is installed without OBDII, or you are using PodiumConnect or RaceCaptue/Apex, you can provide power to ShiftX3 and RaceCapture via a direct wire connection.
  • Note:
RJ45 power cable for ShiftX3
(Note, CAN 1 is not connected on ShiftX3, use CAN2 connection)
RJ45 pin # RaceCapture Connection standard RJ45 pinout CAT5 EIA-T568B RJ45 cable (into ShiftX3)
8 +12v Brown
1 Ground Orange/White
N/C CAN 1 High Orange (No Connection to ShiftX3)
N/C CAN 1 Low Green/White (No connection to ShiftX3))
4 CAN 2 High Blue
5 CAN 2 Low Blue/White
Using ShiftX3
Navigation Buttons
Disco Lights Demo
Script
function rndc()
  return math.random(0,255)
  for i=0,9,1 do
setTickRate(30)
-- can bus: 0=CAN1, 1=CAN2
sxSetConfig(0,0,1)
--create gear channel
--config shift light
  setChannel(gearId, gear)
  sxSetDisplay(0, gear)
setTickRate(30)
sxSetConfig(0,0,1)
Assumptions:
Script
setTickRate(30)
sxSetConfig(0,0,1)
  --update RPM
  --update engine temp alert
  --update oil pressure alert
Assumptions:
Script
setTickRate(30)
sxSetConfig(0,0,1)
Script
-- Predictive time visualizer
--save best lap time
bestTime = 0
sxSetConfig(0,0,1)
setTickRate(30)
  -- rail values
  sxUpdateLinearGraph(timeDiff)
Boost Gauge
Assumptions
Script
setTickRate(30)
sxSetConfig(0,0,1)
  local map = getChannel("MAP")
  if map ~= nil then
    --convert to PSI boost
    sxUpdateLinearGraph(boost)
ShiftX3 CAN bus API
Hardware / CAN configuration
CAN Base Address
Open 931584 (0xE3700)
CAN Baud Rate
ShiftX3 CAN baud rate setting
ADR2 jumper setting Baud Rate
Closed (Default setting) 500K
Open 1MB
ShiftX3 CAN Protocol
Offset What Value
Set Display
CAN ID: Base + 50
Offset What Value
0 Digit index 0 (must be 0)
Set Discrete LED
CAN ID: Base + 10
Offset What Value
2 Red 0 - 255
3 Green 0 - 255
4 Blue 0 - 255
5 Flash 0-10Hz (0 = full on)
Alert Indicators
Set Alert
CAN ID: Base + 20
Offset What Value
1 Red 0 - 255
2 Green 0 - 255
3 Blue 0 - 255
4 Flash 0-10Hz (0 = full on)
Set Alert Threshold
CAN ID: Base + 21
Offset What Value
1 Threshold ID 0 - 4
2 Threshold (low byte)
3 Threshold (high byte)
4 Red 0 - 255
5 Green 0 - 255
6 Blue 0 - 255
Update Current Alert Value
CAN ID: Base + 22
Offset What Value
1 Value (low byte)
2 Value (high byte)
Linear Graph
  • Linear style: stepped
  • Low Range: 0
  • High Range: N/A
  • Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 40
Offset What Value
2 Low Range (low byte)
3 Low Range (high byte)
Set Linear Graph Threshold
CAN ID: Base + 41
Offset What Value
0 Threshold ID 0 - 4
4 Red 0 - 255
5 Green 0 - 255
6 Blue 0 - 255
CAN ID: Base + 42
Offset What Value
0 Value (low byte)
1 Value (high byte)
Notifications
Offset What Value
Offset What Value
Button State
CAN ID: Base + 60
Offset What Value
1 Button ID ID of button
