Harness specifications
Analog / Digital Harness
About this image
8 channel extension
8 to 4 channel splitter
8 channel pigtail
4 channel extension
4 channel pigtail
M8-8P male pigtail for 4 analog or digital channels. Product Info
4 channel splitter
Single channel extension
Single channel pigtail
Oil pressure sensor
Linear temperature sensor
Standardized Connections
  • Connector: M8 4P, A coding
Male connector pictured
Pin Connection Notes
1 CAN low White
3 CAN high Green
4 Ground Black
Dual CAN + power interconnect
  • Connector: M8 6P, A coding
1 CAN1 low
2 CAN2 low
3 CAN2 high
4 Ground
5 CAN1 high
6 Power 9-24v / 1A (~12W)
Single analog/digital channel
  • Connector: M8 3P, A coding
1 Ground Brown
3 Power Blue (5v @ 1A max)
4 Signal Black
Quad analog/digital channels
1 Analog/Digital 1
2 Analog/Digital 2
3 Analog/Digital 4
5 Ground
7 Analog/Digital 3
8 Ground
Octo analog/digital channels
  • Connector: M8 12P, A coding
6 Vref 5v @ 0.5A 5v @ 0.5A
10 Ground
11 Ground
12 Ground
Available cabling
CAN extension cables
Orderable SKU Description
CAN splitter
M8 Power + CAN pigtail
Pinout
  • Red / Pin 2: +12v
  • Black / Pin 4: Ground
  • White / Pin 1: CAN Low
  • Green / Pin 3: CAN High
M8 Power + CAN device pigtail
Pinout
  • Red / Pin 2: +12v
Dual CAN interconnect (RJ45)
Inline CAN terminator
Analog/Digital cabling
Sensor Pigtail
Sensor Extension Cable
Pinout
  • Red / Pin 4 : 5v reference
  • Brown / Pin 5 : Ground
  • Pink / Pin 6 : 5v reference
  • Green / Pin 8 : Ground
