Harness specifications
Revision as of 17:53, 14 September 2022 by Brentp (talk | contribs)
Plug and Play harness system
CAN bus Harness
About this image
Analog harness
The plug and play Analog/Digital harness system lets you easily connect individual sensors to your RaceCapture system, without the need to splice, crimp, or heat shrink connections. Multiple-length extension cables for each stage of the harness lets you build a harness that perfectly matches your installation needs.
About this image
CAN bus harness components
Dual CAN splitter
CAN extension
CAN splitter
Inline CAN terminator
Power+CAN pigtail
Pinout:
  • Red / Pin 2: +12v
  • Black / Pin 4: Ground
  • White / Pin 1: CAN Low
  • Green / Pin 3: CAN High
CAN+power for device
Pinout:
  • Red / Pin 2: +12v
8 channel extension
8 to 4 channel splitter
8 channel pigtail
  • 24 AWG
Pinout:
  • Pin 1: Blue
  • Pin 2: Yellow
  • Pin 3: Green
  • Pin 4: Pink
  • Pin 5: White
  • Pin 6: Red
  • Pin 7: Violet
  • Pin 8: Orange
  • Pin 9: Light Green
  • Pin 10: Grey
  • Pin 11: Brown
  • Pin 12: Black
4 channel extension
4 channel pigtail
Pinout
  • Pin 1 / White : Analog/Digital 1
  • Pin 2 / Yellow : Analog/Digital 2
  • Pin 3 / Grey : Analog/Digital 4
  • Pin 4 / Red : 5v reference
  • Pin 5 / Brown : Ground
  • Pin 6 / Pink : 5v reference
  • Pin 7 / Blue : Analog/Digital 3
  • Pin 8 / Green : Ground
4 channel splitter
Single channel extension
Single channel pigtail
  • 24 AWG
Pinout:
  • Pin 1 / Brown: Ground
  • Pin 3 / Blue: 5V
  • Pin 4 / Black : Signal input
Pressure sensor
Linear temperature sensor
  • Connector: M8 4P, A coding
Male connector pictured
Pin Connection Notes
1 CAN low White
3 CAN high Green
4 Ground Black
Dual CAN + power interconnect
  • Connector: M8 6P, A coding
1 CAN1 low
2 CAN2 low
3 CAN2 high
4 Ground
5 CAN1 high
6 Power 9-24v / 1A (~12W)
Single analog/digital channel
  • Connector: M8 3P, A coding
1 Ground Brown
3 Power Blue (5v @ 1A max)
4 Signal Black
Quad analog/digital channels
1 Analog/Digital 1
2 Analog/Digital 2
3 Analog/Digital 4
5 Ground
7 Analog/Digital 3
8 Ground
Octo analog/digital channels
  • Connector: M8 12P, A coding
6 Vref 5v @ 0.5A 5v @ 0.5A
10 Ground
11 Ground
12 Ground
