Harness specifications
Plug and Play harness system
CAN bus Harness
Analog harness
The plug and play Analog/Digital harness system lets you easily connect individual sensors to your RaceCapture system, without the need to splice, crimp, or heat shrink connections. Multiple-length extension cables for each stage of the harness lets you build a harness that perfectly matches your installation needs.
CAN bus harness components
Dual CAN splitter
CAN extension
CAN splitter
Inline CAN terminator
Power+CAN pigtail
| Pin | Color | Connection |
| 1 | White | CAN low |
| 2 | Red | 9-24v / 1A (~12W) |
| 3 | Green | CAN high |
| 4 | Black | Ground |
CAN+power for device
8 channel extension
8 to 4 channel splitter
8 channel pigtail
- 24 AWG
Pinout:
- Pin 1: Blue
- Pin 2: Yellow
- Pin 3: Green
- Pin 4: Pink
- Pin 5: White
- Pin 6: Red
- Pin 7: Violet
- Pin 8: Orange
- Pin 9: Light Green
- Pin 10: Grey
- Pin 11: Brown
- Pin 12: Black
4 channel extension
4 channel pigtail
Pinout
- Pin 1 / White : Analog/Digital 1
- Pin 2 / Yellow : Analog/Digital 2
- Pin 3 / Grey : Analog/Digital 4
- Pin 4 / Red : 5v reference
- Pin 5 / Brown : Ground
- Pin 6 / Pink : 5v reference
- Pin 7 / Blue : Analog/Digital 3
- Pin 8 / Green : Ground
4 channel splitter
Single channel extension
Single channel pigtail
- 24 AWG
Pinout:
- Pin 1 / Brown: Ground
- Pin 3 / Blue: 5V
- Pin 4 / Black : Signal input
Pressure sensor
Linear temperature sensor
- Connector: M8 4P, A coding
Male connector pictured
| Pin | Connection | Notes |
| 1 | CAN low | White |
| 3 | CAN high | Green |
| 4 | Ground | Black |
Dual CAN + power interconnect
- Connector: M8 6P, A coding
| 1 | CAN1 low | |
| 2 | CAN2 low | |
| 3 | CAN2 high | |
| 4 | Ground | |
| 5 | CAN1 high | |
Single analog/digital channel
- Connector: M8 3P, A coding
| 1 | Ground | Brown |
| 3 | Power | Blue (5v @ 1A max) |
| 4 | Signal | Black |
Quad analog/digital channels
| 1 | Analog/Digital 1 | |
| 2 | Analog/Digital 2 | |
| 3 | Analog/Digital 4 | |
| 5 | Ground | |
| 7 | Analog/Digital 3 | |
| 8 | Ground |
Octo analog/digital channels
- Connector: M8 12P, A coding
| 9 | Analog/Digital B3 | Analog 7 | GPIO 3 |
| 10 | Ground | ||
| 11 | Ground | ||
| 12 | Ground |
