Harness specifications
Plug and Play harness system
CAN bus Harness
Analog harness
CAN bus harness components
Dual CAN splitter
Dual CAN interconnect
M8-6P male to M8-6P male link cable for connecting two CAN bus networks to our Powered Dual CAN Hub. 1 meter length. Product Info
Powered dual CAN hub
Powered CAN hub featuring 8 ports (4 ports for CAN1 and 4 ports for CAN2). Use with the Dual CAN interconnect cable to link to your RaceCapture or PodiumConnect system. Product Info
CAN extension
CAN splitter
Inline CAN terminator
Power CAN pigtail
Pin | Color | Connection |
1 | White | CAN low |
2 | Red | 9-24v / 1A (~12W) |
3 | Green | CAN high |
4 | Black | Ground |
CAN+power for device
8 channel extension
8 to 4 channel splitter
8 channel pigtail
- 24 AWG
10 | Grey | Ground | ||
11 | Brown | Ground | ||
12 | Black | Ground |
4 channel extension
4 channel pigtail
- 24 AWG
3 | Grey | Analog/Digital 4 |
4 | Red | 5v reference |
5 | Brown | Ground |
6 | Pink | 5v reference |
7 | Blue | Analog/Digital 3 |
8 | Green | Ground |
4 channel splitter
Single channel extension
Single channel pigtail
- 24 AWG
3 | Blue | 5v |
4 | Black | Signal Input |
Pressure sensor
M8 Pin | GT150 Pin | Connection |
1 | A | Ground |
3 | B | Power |
4 | C | Signal |
Linear temperature sensor
- Connector: M8 4P, A coding
Male connector pictured
Pin | Connection | Notes |
1 | CAN low | White |
3 | CAN high | Green |
4 | Ground | Black |
Dual CAN + power interconnect
- Connector: M8 6P, A coding
1 | CAN1 low | |
2 | CAN2 low | |
3 | CAN2 high | |
4 | Ground | |
5 | CAN1 high | |
Single analog/digital channel
- Connector: M8 3P, A coding
1 | Ground | Brown |
4 | Signal | Black |
Quad analog/digital channels
1 | Analog/Digital 1 | |
2 | Analog/Digital 2 | |
3 | Analog/Digital 4 | |
5 | Ground | |
7 | Analog/Digital 3 | |
8 | Ground |
Octo analog/digital channels
- Connector: M8 12P, A coding
10 | Ground | ||
11 | Ground | ||
12 | Ground |
