Harness specifications
Plug and Play harness system
CAN bus Harness
Analog harness
CAN bus harness components
Dual CAN splitter
M8-6P male to dual M8-4P female splits CAN1/CAN2 into individual CAN1 and CAN2 connections.
Dual CAN interconnect
Powered dual CAN hub
CAN extension
M8-4P male to M8-4P female cable extends a CAN bus network. Available in 0.5, 1, 2, 3, and 4 meter lengths.
CAN splitter
Inline CAN terminator
M8-4P male to M8-4P female inline 120 ohm CAN terminator - place one near end of the CAN bus network to ensure signal integrity.
Power CAN pigtail
M8-4P male to pigtail for connecting custom device to the Plug and Play cabling system, or for powering a RaceCapture or PodiumConnect system. 2 meter length.
Pin | Color | Connection |
1 | White | CAN low |
2 | Red | 9-24v / 1A (~12W) |
3 | Green | CAN high |
4 | Black | Ground |
CAN+power for device
8 channel extension
8 to 4 channel splitter
8 channel pigtail
- 24 AWG
10 | Grey | Ground | ||
11 | Brown | Ground | ||
12 | Black | Ground |
4 channel extension
4 channel pigtail
- 24 AWG
3 | Grey | Analog/Digital 4 |
4 | Red | 5v reference |
5 | Brown | Ground |
6 | Pink | 5v reference |
7 | Blue | Analog/Digital 3 |
8 | Green | Ground |
4 channel splitter
Single channel extension
Single channel pigtail
- 24 AWG
3 | Blue | 5v |
4 | Black | Signal Input |
Pressure sensor
M8 Pin | GT150 Pin | Connection |
1 | A | Ground |
3 | B | 5v Power |
4 | C | Signal |
Linear temperature sensor
- Connector: M8 4P, A coding
Male connector pictured
Pin | Connection | Notes |
1 | CAN low | White |
3 | CAN high | Green |
4 | Ground | Black |
Dual CAN + power interconnect
- Connector: M8 6P, A coding
1 | CAN1 low | |
2 | CAN2 low | |
3 | CAN2 high | |
4 | Ground | |
5 | CAN1 high | |
Single analog/digital channel
- Connector: M8 3P, A coding
1 | Ground | Brown |
4 | Signal | Black |
Quad analog/digital channels
1 | Analog/Digital 1 | |
2 | Analog/Digital 2 | |
3 | Analog/Digital 4 | |
5 | Ground | |
7 | Analog/Digital 3 | |
8 | Ground |
Octo analog/digital channels
- Connector: M8 12P, A coding
10 | Ground | ||
11 | Ground | ||
12 | Ground |
