Harness specifications
Plug and Play harness system
CAN bus Harness
Analog harness
CAN bus harness components
Dual CAN splitter
M8-6P male to dual M8-4P female splits CAN1/CAN2 into individual CAN1 and CAN2 connections.
Dual CAN interconnect
Powered dual CAN hub
CAN extension
M8-4P male to M8-4P female cable extends a CAN bus network. Available in 0.5, 1, 2, 3, and 4 meter lengths.
CAN splitter
Inline CAN terminator
M8-4P male to M8-4P female inline 120 ohm CAN terminator - place one near end of the CAN bus network to ensure signal integrity.
Power CAN pigtail
M8-4P male to pigtail for connecting custom device to the Plug and Play cabling system, or for powering a RaceCapture or PodiumConnect system. 2 meter length.
Pin Color Connection
1 White CAN low
2 Red 9-24v / 1A (~12W)
3 Green CAN high
4 Black Ground
CAN+power for device
M8-4P female to pigtail for a custom-wired non Plug and Play connection to one of our CAN bus enabled devices such as TireX, AnalogX2, or ShiftX3
1 White CAN low
3 Green CAN high
4 Black Ground
8 channel extension
Male to Female M12 12P cable extends 8 analog or digital channels. Available in 1 or 2 meter lengths.
8 to 4 channel splitter
M12-12P male to dual M8-8P female connector splits 8 analog or digital channels into dual 4 channel connections.
8 channel pigtail
M12-12P 0.3 meter male pigtail breaks out 8 analog or digital channels.
  • 24 AWG
10 Grey Ground
11 Brown Ground
12 Black Ground
4 channel extension
M8-4P male to M8-4P female cable extends 4 analog or digital channels. Available in 1 and 2 meter lengths.
4 channel pigtail
M8-8P male pigtail for 4 analog or digital channels. 1 meter length.
  • 24 AWG
1 White Analog/Digital 1
2 Yellow Analog/Digital 2
3 Grey Analog/Digital 4
4 Red 5v reference
5 Brown Ground
6 Pink 5v reference
7 Blue Analog/Digital 3
8 Green Ground
4 channel splitter
M8-8P Male splits 4 analog or digital channels into 4 M8-3P female connections.
Single channel extension
M8-3P male to M3-3P female extends a single analog or digital channel. Available in 1, 2, 3, and 4 meter lengths.
Single channel pigtail
M8-3P male pigtail for a single analog or digital connection. 2 meter length.
  • 24 AWG
1 Brown Ground
3 Blue 5v
4 Black Signal Input
Pressure sensor
M8-3P male to 3 pin Delphi GT150 pressure sensor connector. 2 meter length.
  • 10 bar/150 PSI
  • 150 bar/2175 PSI
M8 Pin GT150 Pin Connection
1 A Ground
3 B 5v Power
4 C Signal
Linear temperature sensor
M8-3P male to linear temperature sensor. 2 meter length.
  • Connector: M8 4P, A coding
Male connector pictured
Pin Connection Notes
1 CAN low White
3 CAN high Green
4 Ground Black
Dual CAN + power interconnect
  • Connector: M8 6P, A coding
1 CAN1 low
2 CAN2 low
3 CAN2 high
4 Ground
5 CAN1 high
6 Power 9-24v / 1A (~12W)
Single analog/digital channel
  • Connector: M8 3P, A coding
1 Ground Brown
3 Power Blue (5v @ 1A max)
4 Signal Black
Quad analog/digital channels
1 Analog/Digital 1
2 Analog/Digital 2
3 Analog/Digital 4
5 Ground
7 Analog/Digital 3
8 Ground
Octo analog/digital channels
  • Connector: M8 12P, A coding
6 Vref 5v @ 0.5A 5v @ 0.5A
10 Ground
11 Ground
12 Ground
