ESP32-CAN-X2
- Reset and Boot push button
- Integrated CAN transceivers
Getting started
Microcontroller
External Connection Header
In addition to the microcontroller, external headers, SV1 & SV2, are the two other important components of this development board. SV1 is the left side dual row header and the SV2 is the right side dual row header. Both of these headers have 20 pins available for connection. These headers provide connections for GPIOs, power output, ground (GND), power input, and CAN communication pins. Both of these header pinouts have standard size, allowing users to connect them using jumper wires, a breadboard, or even solder wires permanently onto the development board. However, while doing the wire connection the customer must make sure that none of them get short circuit. The details regarding the pin's names, numbers, outputs, and functions are given in the Board Pinout section below.
CAN Controllers
Internal pinout connections of the CAN controllers:
6 pin JST-PH Connector
In addition to the 40 pinouts of the Header SV1 and SV2, the ESP32-CAN-X2 development board also provides an additional 6-pin connector header at the top of the board to supports CAN communication. This header makes wiring the device more convenient and robust. The CAN communication connection pinout details are given in the pinout section below.
USB-C Socket
Board Layout
- Width : 42.10 mm
- Length : 72 mm
Power Options
Pin Voltage
VIN Rating
Operating Current
Power Consumption
Operating Temperature
CAN bus information
Board Pinout
| 5 | RX Pin | USART RX |
| 6 | TX Pin | USART TX |
| 7-20 | GPIO Pins | GPIO's |
| 1-11 | GPIO Pins | GPIO's |
| 12-13 | Vin | Voltage Input |
| 14-15 | 5V | 5 Voltage Output |
| 16-18 | GND | Ground |
| 19-20 | 12 Vin | 12 Voltage Input |
Top Header Pinout
| 4 | GND | Ground |
| 5 | CAN2H/2.7A | high-level signal for the first CAN channel |
| 6 | +12V_ Aux | 12V power supply |
Flashing firmware
