ESP32-CAN-X2
Purchasing
  • Reset and Boot push button
  • Integrated CAN transceivers
Bolt-ons
Make your own bolt on with a blank design template https://github.com/autosportlabs/ESP32-CAN-X2/tree/main/bolt-on-template
GPS bolt-on
Adds a high performance GPS receiver
Button bolt-on
Adds 4 tactile switches + RGB LEDs
RGB LED bolt-on
Adds 10 RGB LEDs across two groups for alert indicators
Getting started
Figure 1
Microcontroller
Figure 2
External Connection Header
CAN bus transceivers
The following are the specifications of the CAN transceivers for CAN1 and CAN2:
Detection of Ground Fault
  • Permanent Dominant Detection on TXD
  • Permanent Dominant Detection on Bus
  • Power-on Reset and Voltage Brown-Out
Protection on V DD Pin
  • Protection Against Damage Due to Short-Circuit
Conditions (Positive or Negative Battery Voltage)
  • Protection Against High-Voltage Transients in
Automotive Environments
  • Automatic Thermal Shutdown Protection
  • Suitable for 12V and 24V Systems
  • Meets or exceeds stringent automotive design requirements including “Hardware Requirementsfor LIN, CAN and FlexRay Interfaces in Automotive Applications”, Version 1.3, May 2012
• High-Noise Immunity Due to Differential Bus Implementation • High Electrostatic Discharge (ESD) Protection on CANH and CANL, meeting the IEC61000-4-2 up to ±14 kV
CAN Controllers
CAN 1
This is a built-in CAN controller and its RX is connected to IO6 of the microcontroller and TX is connected to IO7 of the microcontroller. The connections are shown in Figure 3 given below
CAN 2
This is the externally connected MCP2515 controller with the following connections:
MCP2515 ESP32-CAN-X2 GPIO connections
Signal ESP32 GPIO
CS 10
CLK 12
MISO 13
MOSI 11
IRQ 3
Crystal: 16MHz Figure 3
Two 4-Pin header Connector
Built-in LED
USB-C Socket
Debug Connector
The following 6-pin connector marked as X4 is used for serial communication and debugging purposes with ESP32 CAN X2. The 6-pin configurations on the ESP32 CAN X2 is arranged as follows:
Figure 4
Board Layout
  • Width  : 42.10 mm
  • Length : 72 mm
Power Options
Power available to your circuit
The onboard regulator can provide power to your devices:
  • 1.5A is available on the 5V header pins
  • 100mA is available on the 3.3v header pins
Pin Voltage
VIN Rating
Operating Current
Power Consumption
Operating Temperature
CAN bus information
Multimaster system
Lossless communication
Simple and cheap
Errorless communication
CAN network types
Data transmission
Note : The low-speed CAN, single wire CAN, may not require the CAN bus termination.
Board Pinout
Figure 7
Pin Function Description
5 RX Pin USART RX
6 TX Pin USART TX
16-18 GND Ground
12v note
Top Headers Pinout
Figure 8
1 +12V_AUX 6-12V Power Supply
4 GND Ground
4 GND Ground
Pigtail for Plug and Play Harness
A pigtail is available for connector X1 and X2 that can integrate with the Autosport Labs plug and play harness system. This pigtail can provide power + CAN data to the board.
3D printed enclosure
You can 3D print your own enclosure: files available on Github.
The enclosure is a snap together design with ports for USB and grommets holes for the plug and play harness.
Flashing Firmware
Hardware Components
  • USB-C cable
Software Components
Note : Link to download Arduino IDE : https://www.arduino.cc/en/software || Link to download Mu Editor : codewith.mu
Sample Arduino Project
  • Open Arduino Ide
  • Go to File > Preferences
Figure 7
Json URL : https://espressif.github.io/arduino-esp32/package_esp32_index.json
Figure 8
Figure 9
Figure 10
Flashing
Figure 11
Figure 12
Sample CircuitPython code
Installing ESP-32-X2 is simple, please follow the steps given below :
Click on the browse S3
  • Select the desired language
Flash the Firmware
written.
Exit Bootloader Mode
Importing libraries in Circuitpython is straightforward. For installing Libraries in Circuitpython, please follow the steps given below :
  • Extract the zip file.
ESP32-CAN-X2 Rev-C
ESP32-CAN-X2 Rev-C
