ESP32-CAN-X2
- Reset and Boot push button
- Integrated CAN transceivers
Getting started
Microcontroller
External Connection Header
CAN Controllers
6 pin JST-PH Connector
USB-C Socket
Board Layout
- Width : 42.10 mm
- Length : 72 mm
Power Options
Pin Voltage
VIN Rating
Operating Current
Power Consumption
Operating Temperature
CAN bus information
Board Pinout
| 5 | RX Pin | USART RX |
| 6 | TX Pin | USART TX |
| 7-20 | GPIO Pins | GPIO's |
| 1-11 | GPIO Pins | GPIO's |
| 12-13 | Vin | Voltage Input |
| 14-15 | 5V | 5 Voltage Output |
| 16-18 | GND | Ground |
| 19-20 | 12 Vin | 12 Voltage Input |
Top Header Pinout
| 4 | GND | Ground |
| 5 | CAN2H/2.7A | high-level signal for the first CAN channel |
| 6 | +12V_ Aux | 12V power supply |
Flashing firmware
